Question about Sony Televison & Video
SONY Bravia KDL-40XBR4 HDMI problem
One of the HDMI inputs is not responding. There are 2 on the back that I am using. One for the cable box and one for the Sony DVD player. Both are brand new and I could see the DVD player at first...until I couldn't.
Here's the thing: when I switch the two cables I can see the DVD and not the cable box. This would indicate to me that it's the HDMI jack on the back of the TV and not the cables or the DVD player.
Am I missing something?
  • Sony Master
  • 460 Answers
Ok i am assuming that when you switched the cables you only did so on the devices and not on the back of the tv. Am I correct on that? If so then you did not actually test the ports on the or the cables. It is cheaper to replace the cable than it is the port on the tv. I recommend taking each cable one at a time, ( remove the other cable completely during the test) hook up one cable to dvd player, then connect it to port 1 put tv on that channel and see if it works, now hook up that cable to port 2 while leaving it connected to the dvd player and change the channel and see if it works. now remove that cable completely and try the same steps with the other cable and compare the results. If it is a bad cable one cable will work on both ports and one will not work at all. If it is a bad port then both cables wil work on one port and not the other port. There is no need to use both boxes for this test due to the fact that in your original post you switched the boxes and a different one worked when you did.
Posted on Jun 11, 2017
SOURCE: How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
Posted on Sep 26, 2008
  • 320 Answers
SOURCE: Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Posted on Oct 19, 2008
SOURCE: YSP: Need remote code for TV Sony Bravia KDL-46W4500
Use codes 263, 214
Posted on Jul 12, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
Does anyone knows why an orange led flashes 3 times on the FB1 board that seems to trigger a reset of the TV's POWER ON SELF TEST causing the set to go into a cycle of booting and re-booting.
you always power on external boxes
wait till they settle then power on the TV etc
and look up the box on its input or switch the box to standby
power on the tv
then power on the TV and wait like 1 min
then power on any scart or hdmi input
then any TV will auto switch to the last detected input
Mar 26, 2015 | Sony Bravia XBR-Series KDL-40XBR4 40-Inch...
Sony Bravia KDL 52Z5100 - no sound only picture. HDMi cable works fine with another TV, so no probs with cable TV.
A short fix is to unplug the hdmi cable and shut down the tv compleetly, then get the tv on and plug it in, the tv see the new connection and reset the value's for sound
Feb 15, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Just set up the tv... have cable going to hdmi 1 and dvd to hdmi 2... checked all wires, but tv saying NO SIGNAL... wondering what am missing. is there a setting i have turn on for hdmi input
On your Sony TV remote, press the "Input" button and make sure you select HDMI 1. Also, check to make sure you HDMI is plugged into your cable box.
Feb 14, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
KDL-40V5100 TV HDMI Issue
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
I have a sony bravia kdl 37m3000. We have cable and the wide screen would not go away so we unplugged the cable to reset the tv. Now the cable and the tv comes on but no picture.
Make sure you change the input that the cable is coming in on, If you was watching in HD mode then you was using an HDMI or compontet hook up.Look on tv remote for Video input button to select the componet input 1 or 2 or HDMI inputs which it is connected to. Look for a button on the remote called TV/VIDEO or INPUT
Dec 15, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Jan 19, 2008 | Televison & Video
Televison & Video Logo
207 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
