Question about Ricoh Aficio 1035 Copier
Wont recognize the network and the network can see it
There is a small red light flasing in the left side of the back of the main part of the unit where it attaches to the smaller piece. My network cannot see the unit... it can copy with no problems the only thing it cannot do is print from the server or see it. I have already tested the patch cables and the switch it is on and they are all in great working condition. I am befuddled. Can anyone help ?
Thank you
Jo =)
  • joval Jan 19, 2008
    Thank you very much... It ended up being the plug in wire that is sorta wide just beneath the hard drive in the back right side of the machine.... it had come loose just enough not to make contact.
    Thank you again
    Jo =)
Make sure the network ip address/subnet are correct. You can enter them manually through the user tools interface. If the settings are correct then the NIC is bad.
Posted on Jan 17, 2008
Luxor tv will not power up and red light just keep flashing
I just pull out the mains plug for a few seconds then put it back in. The red light keeps flasing for a while (be patient) then stays solid red. When I then switch on again with the remote it is fine. I often have to do this.
Jul 27, 2012 | Televison & Video
My red and green light wont stop flasing. i have put new cartridges in.
If the pair is the green power light and the red paper light that are flashing, then you have a paper jam. You need to check the paper path (it's possible that a small piece of paper tore and is causing the jam).
I hope this helps.
May 21, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Flasing red light xbox360
get the number for microsoft and get a free refund thats what i did
Oct 26, 2009 | Video Game Consoles & Games
Sevice tool light blinkin and error c05
Sir,
To clear this code requires you be in front of the machine, to the right side of the machine, just below the large glass is a cover remove it if you copiers is networked the cover is where the network cable connects. Once the cover is removed look inside you will see a small black button press it then get back to the operator panel you will see "Please wait" then you will see a small dot on the screen on the lefthand side of the screen when you see the dot press "3" you will see a 'TROUBLE RESET" PRESS the OK letb the machine go thur the motions this time when you see the dot do noting. Once ready to copy, turn off the machine both power switches main sw is in the back left side of machine then turn the pwr switches back on if this is not done your Start button will continue to blink on/off. If the code comes back your fuser unit needs replacement or worse the main board:(
Sep 02, 2009 | Minolta bizhub 350 Black and White Copier
RED LIGHT FLASHING NOTHING ELSE WORKS
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Jul 25, 2009 | RIM Blackberry 8110 Cellular Phone
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Red light above display flashes but no functions working
hi Dave
I'm not the most technical person in the world but I think I've fixed mine which had the same problem this afternoon, which is how I came to find your message!
Right.. here's what I did. It would appear that you have some kinda mechanism jam (even if there's no disc in it), so... please excuse my non-techie terminology throughout.
By the way, I probably don't need to tell you this but unplug the unit from the mains first or you might light up if you touch something!
Working with the unit facing you (control side), remove the two small screws at the back (on the metal flange) and two medium screws from the right hand and left hand sides of the main casing, then slide it off from front to back so that you can see inside the recorder. If you look in and down at the CD tray transport mechanism you should see a white plastic 'cog' wheel on the left hand side of the unit near the bottom 'floor' of the machine. Carefully rotate this wheel with a finger CLOCKWISE (pushing the wheel from front to back), slowly and gently - don't force it - and you should see the CD tray mechanism and gubbins start to move; keep rotating until the tray comes right out, or as far as you think it goes. Then, plug the unit back in, and switch on - the tray SHOULD then be taken back into the machine, the red light will flash, and the display should come on. As I say, mine has, so try it and I hope it works for you!
All the best (we'll beat these damn machines yet!)
Kev
Apr 16, 2009 | Pioneer PD-R509 CD Recorder
Car battery died, radio wont turn on anymore
Have you checked the fuse at the back of the head unit. You will need to extract the head unit from the slot. There is a small blade fuse near to where the wiring harness connects to the back of the unit. Check it to see if it has blown. It normally is a red 10amp fuse.
Also check your main fuse board.
Hope this helps
Regards
Oct 16, 2008 | Pioneer DEH-P6800MP CD Player
KLV 40S200A
If you watch how many times the light flashes and then relay that to your local authorized sony repair centre they will tell you what is likely wrong with the TV. Have you unplugged, left for a couple of minutes and re-plugged?
Sep 07, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Flase red light when turn on
Looks like the fall damaged the unit. Try turning it in for warranty. Off course don't mention the falling. Just tell them the yellow light appeared out of nowhere.
It's still risky though, if Sony suspects something happened to it before this problem they will probably not trade the unit or let you pay for a new one.
Greetings,
DarkNeogen
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Ricoh Aficio 1035 Copier Logo
151 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
