Question about Sharp AR-207 Copier
Copier won't print
It is flashing H - 4
Has a bad fuser unit and may need to reset code with sim 14....
Posted on Jan 17, 2008
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
Toshiba e-studio 120 copier. Won%u2019t work. Flashing H, flashing 4.
hi H4 is a fusing unit problem check your heater for a poor contact or open thermal fuse
Oct 24, 2010 | Toshiba Office Equipment & Supplies
I replaced a new drum cartridge for Sharp AL-1631 Copier, but the warning indicator light is still on and the copier is not working.
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL-1641CS Color Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
A flash light is on. The copier is not working even I replaceed with a new SH-AL-100TD cartridge.
I beleive this "flashlight" is the drum cartridge light. You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Oct 28, 2009 | Sharp AL 1631 Copier
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cs-2114 all dark copies
if you replace drum meanwhile you have to replace developer too, after you replace then you have to simulated follow these steps;
1, power off,hold down"print"&"stop/clear" key while you turn on.
2,press"stop/clear" key within 2 second.
3,enter 60, press print,pess "'stop/clear" key
4,enter 73, press print, enter000000 press print
5, mode 1, enter 03 press print mode 2 & 3 all enter0 press print
Dec 12, 2008 | Office Equipment & Supplies
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
H 4 flashing problem
H4 flashing on Sharp copiers indicates that the fuser tempurature has failed to reach temperature in a given time. The posible causes of this are 1.Failure of the heater lamp or heater lamp drive circuit. 2. Failure of the temperature sensing circuit. 3. The initial temp. of the fuser roller was very cold. or 4.low mians supply voltage for a short time (brown out). The copier does not allow a simple on/off reset of this fault because in cause 2. above the copier may overheat and cause a fire.
The reset for this model should be:
Clear ® Density select ® Clear ® Density select - 14-Print.
May 27, 2008 | Sharp AL-1642CS Copier
Sharp AR-207 Copier Logo
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
