Question about Vtech VT-9118 Cordless Phone
Ringer off how do you turn off the ringer on vtech chordless phone
  • 4 more comments
  • Anonymous Apr 24, 2008
    Wow I cannot turn the ringer off. Does anyone know if that's possible??
  • Anonymous Jul 30, 2008
    I want to turn the ringer ON, not it's off and I don't know how to do it. Can you help me?
  • Anonymous Sep 07, 2008
    I need to turn the ringer OFF from the base unit from time to time. Is this possible
  • Anonymous Oct 16, 2008
    My display is saying 'RNGOFF' and I don't know how it happened or how to get my ring back...
  • Anonymous Oct 27, 2008
    same pblm dont know how to on the ringer
  • Anonymous Apr 12, 2009
    No Ringer. same thing.
    Problem Solver:
  • 5 Answers
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Posted on Apr 17, 2009
I had the same problem but solved it last night. Here is how I fixed it.
On the base you have to hit set up and go through the different options to turn the ringer on or off.
On EACH handset you have to set the ring volume and tone.
Press the menu/select button it will say directory and call log and that's it right? Well the menu is BACKWARDS. You scroll UP with the volume button in the middle and you will get all the other options....home area code, clear voice mail, language, key tone,ringer tone, ringer volume, call log and directory. Highight the one you want and hit the menu button again to change the settings. You have to adjust the ring for each handset not just on one for all. Good luck.
Posted on Jan 19, 2009
HOW DO YOU TURN OFF THE RINGER ON UNIDEN CHORDLESS PHONE
Posted on Nov 18, 2008
Hi, got solution for this problem. you need to deregister it using global setup & then it'll ask you to put your handset back to base station for registration, so just connect it back to base station. it's a kind of reset but helps to get ringer working. it worked for me & i'm happy after little r&d.
Posted on Nov 07, 2008
Same problem. the mannual is bar far the worst worst worst mannual ever. cannot turn the ringer on and still have the ring off message. just appeared out of nowhere
Posted on Oct 31, 2008
How do turn off the ringer?
Posted on Mar 03, 2008
How do I turn the ringer on, it rings in the back but not at the front desk
Posted on Jan 26, 2008
3 Suggested Answers
  • 102366 Answers
SOURCE: ringer off
http://www.vtechphones.com/vtechui/support/manual_list.cfm
Posted on Jul 19, 2010
SOURCE: turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Posted on Jan 19, 2008
How do I turn down volume on ringer vtech dect 6.0?
With many VTech phones, you simply press the down-arrow or - key while the phone is in standby mode.
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Dec 06, 2013 | Vtech DECT 6.0 Digital Cordless Phone
My cordless phone a vtech 5.8GHz The ringer is turned off and I don't know what to do to turn the ringer back on.this is an older phone and i've misplaced my manual.,
Since you neglected to specify the model of your VTech 5.8GHz phone, I can only direct you to enter it into the search box here to download a copy of the manual.
Jan 30, 2012 | Vtech 5.8GHz Analog Cordless Phone
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Thank you for using FixYa.
Have a great day.
Jas247
May 17, 2011 | Vtech Cordless 6041 Phone
I got a vtech chordless phone and 1 of them will not connect,how do i reset the phone
For this,check for a reset button below the main unit or the handset. This would reset your button,refer to your user manual on how to set it up.
Mar 23, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I lost directions and would like to block calls on my chordless vtech
You can download the manual from the manufacturer's web site at
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=314062
Aug 20, 2010 | Vtech CS5121 Cordless Phone
My Vtech 5.8 cordless phone says ringer is off. How do I turn ringer back on?
press and hold menu button. Find ringer, push up button to change ring volume.
Nov 17, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
My vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
May 30, 2009 | Vtech 5867 Cordless Phone
Ringer off
Mar 10, 2008 | Memorex 2.4GHz Phone (MPH7828)
Turn the ringer off
Base Ringer:
Handset:
Jan 17, 2008 | Lands Phones
Vtech VT-9118 Cordless Phone Logo
1,208 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
