Can't turn on speakers on my monitor x2gen
SOURCE: X2Gen Monitor speakers not working
This sounds like a straight hardware issue. However, to be certain, try to attach another monitor to this PC, and if it works properly, you will know that there is nothing wrong with the graphics card/driver or other related component of the PC involved. (Also make sure you are using the proper type of cable - analog/digital - for the connection.) Also suggest switching out cables to eliminate that. Further, you could try to see if the monitor functions properly when attached to another machine. If the machine is not functional and another is, that will confirm that the issue is hardware-based.
Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer, or perhaps through a credit card company, this would be your best recourse. Here is the link to the form via which you could file a bankruptcy claim: http://www.x2gen.com/files/Claim.pdf. Hope this may help, if you can't get reimbursed through some other means.
My experience with this type of issue is that the hardware has gone bad. Particularly with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
If the monitor continues to behave in the same manner, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not - in other words, if you see something different with switch of connections/machines, there could be a graphics card/driver or other issue that we could work on further.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa!
SOURCE: no sound from monitor speakers
you have to enable the onboard sound card as a primary sound of your computer
i have a 42 inch lcd monitor. the speakers on the tv will not come on. i have a surround system hooked to it with rca plugs and that is the only way i can get sound. i have tried every thing i can think of thru the osm. my monitor has tuner, composite, s-video, component, hdmi, vga, vga-componet for the sourcesi am not using the tuner source as i have a dvr from directtv hooked to it and a dvd player. i use component for dvr and s-video for dvd. i have a rca plug to video in for dvr and s-video plug for dvd. the auido plugs run to my surround sound. the volume line shows up when i turn it up & down and i made sure the mute was off.i should have tv speakers no matter what source i use. your help is very much needed. [email protected]
X2Gen MW19U 19in LCD flat panel monitor w/ Speakers and can't turn speakers on.
Hi
Do you have a seperate button on you monitor to turn on the speakers?
Need more details as to wht the problem is?
