If it is making a noise that sounds like a knock you could have a broken mount bolt. Pull the agitator out, remove dispenser or cap, take out inner cap, rmove bolt, agitator should pull out. now you can see the hub and the two bolts that hold the tub onto the shaft. one of the bolts could be broken. If it is go to the hardware store and get new stainless steel bolts and replace both. Also get some blue loc-tite or permatex, or the bolts can come out of the block. Hope this helps.
This is normal becalse it goes faster on the final spin DONT WORRIE!
