Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Green light blinking, tv won't turn on
We have turn off the power, and hit reset button and light keeps blinking. has been blinking for over hour now
same problem green light keeps blinking but wont come on how can i fix the problem?
    Genius:
  • 1,226 Answers
Unplug to the wall outlet for an our to reset all setting of the TV and switch back soon to test.
If not solve the problems, Maybe you should call service center of your TV or the store where you buy that TV because the store technician know already of there procuct will be blinking soon. this only can be fixed by there own technician. If the your TV has a warranty then theres no cost on that.
Posted on Jan 17, 2008
    Scholar:
  • 128 Answers
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
4 Suggested Answers
  • 1153 Answers
SOURCE: green light blinking, tv won't turn on
Look for DM board repair here in threads
Posted on Jan 04, 2008
  • 5 Answers
Hey guys/gals, I was having the exact same problem with my 55" mitsubishi...then I came across this thread..
click here
and now I am watching my TV again!!
Just four bad capacitors were the problem. It's fairly common and the capacitors cost me about $3.
in case the link doesn't work, you can find it here..
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Posted on Feb 13, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
Apr 03, 2010 | Mitsubishi WD-52528 52" Television
Tv will not turn on,just has the flashing green light.after reseting the tv via the reset button the same problem persits
try hitting the sleep button over and over it reset my timer and I have had no more blinking green light problems
Nov 15, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
