Question about Vacuums
Miele Vacuum Cleaner
Have a Miele 700 which will not run. Power light shows but on preesing "Run" switch this goes out but may light again after a time.Have some idea the main cover safety switch may be faulty.
  • Colruss Jan 17, 2008
    Thanks query reddevil6 the face plate data is:-
    Type HS 05, Model S718
    Top of machine says:- Solution H.E.P.A 700
    Hope you can help,
    Regards Colruss.
  • Lauren Junge
    Lauren Junge May 11, 2010
    What is the correct model number for your miele, 700 is not it.
  • 1,673 Answers
S718 doesn't come up in the Meile parts list, there is a S518, some possibles to check: The switch part #04367102, Indictor lite w/pot. # 05482010, Reel cord 05240302, and motor electronic control # 05408620. Any one of these could be giving you the problem you describe. You will have to dive in and starting with the switch, and eliminate which ever parts seem ok. The reel cord could have bad internal contacts, I have had the pots go bad, but the electronic control more ofter. Which I could pin point it for you.
Posted on Jan 18, 2008
Thanks reddevil6 - will pursue the items you mention and report outcome as soon as possible.
Much appreciated,
Regards, Colruss.
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
Can anyone please help, my Miele vacuum cleaner will not switch on anymore.
Most likely problem one of the wires leading to the switch. Ohm them out with a OHM function of a multimeter, while unpluuged , of course. .
Sep 14, 2014 | Miele Vacuums
My parents have a miele vacuum cleaner model s538. Do you know where I can obtain a repair manual for this vacuum cleaner. It is always on the "fritz". The vacuum has been taken for several...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jul 07, 2011 | Miele Leo S5381 Canister HEPA Vacuum...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
The vaccum can not work.
possible solution:
I had the same problem. try plugging in & pulling cord out of rewind a number of times. if motor goes on, you need repair on cord winder. per miele tech-"not common prob.", but repairman said "yes, common prob." good luck.
Mar 25, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
313 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
