Question about Panasonic Car Audio Receivers
2003 Nissan Altima Car Stereo CD Player
I have a 2003 Nissan Altima 2.5 S with the original radioo and CD player. Recently when I try to play a CD I get a popping sound. I checked the wiring plugs and sockets and they seem okay. What might be the problem?
c renner
  • 43 Answers
SOURCE: radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Posted on Mar 08, 2008
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
SOURCE: Pioneer automotive stereo cd player error 11
I have the same problem now too. It shows up error 11, 12 or 17. I tried using a cleaning CD but did not work. I think the lens needs to be replaced.
Posted on Aug 06, 2008
SOURCE: Car stereo installation
i have a 1999 escalade i got a avh p-5700 pioneer my truck has a built in amp and when i hooked up i cant get sound
Posted on Jun 21, 2009
SOURCE: CD got stuck in CY620(Nissan Sentra-2004 1.8S)
r4speed. Thank you. You hit the nail on the head!. take out the stereo from the car. take off the cover. unscrew small screws which hold the similar shaped steel box inside the stereo, which houses the gears. see the clear plastic cover over the gears. unscrew the screw which holds this cover down. see the broken off edge of the cover which comes off along with the screw. use super glue to glue this bit of small plastic back onto the edge of the gear cover. when dry and glue has set, screw cover back down, and reverse of disassembly. yeaaa for r4speed!!!!
Posted on Dec 10, 2009
  • 166 Answers
SOURCE: Need Wiring Diagram for a Pioneer MOSFET 50 Wx4
Found the manual on Crutchfield's site
The wiring diagram is on Page 25
Posted on Jan 23, 2010
0 characters
1 Points
C.d player doesnot play
Not all in-car stereo are compatible with computer recorded CD.
Try setting Roxio to "Close Disk" and "Close Session" or "Disk at Once" (try all) while recording the CD on PC.
If that does not work, then the stereo is not compatible with recorded CDs.
May 27, 2010 | Clarion DXZ838RMP CD Player
Will not play burned cd's. Getting ERROR 3 message.
have you tried using cd + or - r's and some units dont recognise all,also cd player may only read mp3 format dics, not itunes, you can reformat using software from web site....... swift sound file converter
Jan 01, 2010 | Durabrand Car CD Player and AM/FM...
I have a Naxa car stereo the Model is NX-680
sounds like the deck is hooked incorrectly
Jun 02, 2009 | Car Audio Receivers
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Put an aftermarket stereo in my 2006 nissan altima stereo turns on and works but it blows my 10 amp taillamp fuse. makes my ac knob lights turn off my gearshifter indicater turns off as well foglamps and...
The problem is bad wire connections, check the connections you made, if you don't understand the diagrams go to an expert.
You can cause major problems if you keep trying and doing it wrongly.
If you know what you're doing, if everything is ok and the problem persists try the same stereo in another car to check if the problem is that.
May 02, 2009 | Kenwood KDC-MP205 CD Player
Citroen Saxo CD Player will not play when engine running
The car stereo has 2 +12V inputs: the constant batt input and the key in one.
So actually the stereo is always connected to +12V, even in standby.
When you turn your key, the key in input also starts, thus starting your stereo instantly.
When you turn the ignition on, the key in input is switched off for a couple of seconds, so that all the power goes to starting your engine.
After that key in input should be back on - this is your problem here.
One possible solution would be to cut this wire out, and split the RED battery +12V cable so that it enters in the key in input as well. Check wiring diagrams!.
Test this with cables out (without reinstalling the whole thing back in) and if it works.......leave it and put everything back in.
Only downside is, you have to turn off the radio by hand when you exit your car - or you could lose all battery power !
Jan 16, 2009 | Car Audio Receivers
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Cd player cutting out when volume is high
you prolly need a new voltage regulator
May 14, 2008 | JVC KD-G720 CD Player
Error message with new CD-R copies.
DUUUDE...I am having the exact sasme problem!!! I almost threw the damn stereo out the window on the way to work.
Aug 22, 2006 | Alpine CDA-7892 CD Player
Car Audio Receivers Logo
246 people viewed this question
Top Panasonic Car Audio Receivers Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio Receiver Expert? Answer questions, earn points and help others
