Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother all in printer, fax problem
I have five lines in my new business, one of the line is shared by fax and DSL. I have problem receiving fax. I can hear the incoming faxes, and see my fax showing receving, then after few rings, it stops, nothing come out. Please help.
  • anakinra Jan 22, 2008
    I do have the DSL filter installed on the phone line. I still can't receive fax. I can send fax ok.
  • anakinra Jan 24, 2008
    the fax machine is connect directly to the phone jack on the filter unit. fax works with other phone line. If the problem is in the phone wiring, do I contact Verizon?
    Scholar:
  • 128 Answers
Call Brother Customer support at 1-877-BROTHER (877-276-8437)
Posted on Jan 17, 2008
    Novelist:
  • 139 Answers
Make sure you have a DSL Filter installed on the phone line to prevent DSL signals from interfering with the operation of the fax machine. A DSL filter looks like a line splitter or Y-Adapter and you should have received one or more of them with your DSL modem.
  • networkmagic Jan 22, 2008
    It seems too simple...but make sure the fax machine is connected directly to the Phone jack on the filter unit...and not to the DSL jack. Also, check the fax machine to make sure it's ok by connecting to one of the other phone lines for a test.
    If the fax machine works ok on another phone line, the problem is either in the phone wiring, or the fax machine is unusually susceptible to interference from the DSL signals.
  • networkmagic Jan 24, 2008
    Yes...if Verizon is your local phone service provider.
    You can check the fax line yourself to see if it has any obvious problems by connecting a phone to it. If a phone works ok on the fax line, then the problem is probably related to the DSL service. Fax machines can be sensitive to line conditions that humans may not be able to hear. A Verizon customer service representative may be able to offer more advice on this. My suggestion would be to request a change of the dsl service from the fax line to one of the other phone lines. Unfortunately, that will probably result in additional phone company charges.
6ya staff
SOURCE:
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
Brother Inellifax 4100e will not send
It appears that you have interference somewhere in the office. Have you recently gone to DSL in the office? A DSL line transmits a signal that requires a filter to receive only phone signals instead of the DSL signal. If the fax machines are receiving an unfiltered DSL signal, this would explain the interference. If this is not the case, the link below is a Brother's Solution to the NG Poor line quality. Best of luck to you with your fax problem.
Greg
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000200/000009/faq000209_002.html?reg=us&c=us_ot&lang=en&prod=mfc6490cw_all
May 12, 2009 | Brother IntelliFAX 4100 Laser Fax
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Stand-alone fax machine share the line of a business extension?
Only for outgoing faxes. You would need fax server software to receive
Feb 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Brother 1840 bleeps
Try to unplug the handset and try again.
Unplug the phone cords from any shared devices.
Do you have DSL or any other digital type phone line?
Make sure the phone cord is plugged into the LINE port of the fax machine.
Jul 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Mar 18, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
132 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
