Hi, I have a gas water heater and my water is running cold. I cut the switch off and turned it back on and the fan turned back on and we had hot water again. Now it is completely cold or very luke warm water.
Sounds like it is the pressure diaphram.This is a object that looks like a space ship or ufo undo all the screwss on the flatish side after isolating the water supply revove old diaphram & install a new one
certain water heaters had a tube that dissolved, you take 1/2 in. copper flare one end of it, drill a1/8 in. hole in pipe 4 in. below flare ,remove cold water nipple on tank install new copper tube, cut tube to 3 inches off bottom of tank depth , reconnect cold water supply you should be good.
It is probable the cold water comes in from the outside pipe so will be unaffected by anything that happens to your boiler/water heater. The boiler/ Water heater must have an issue, the problem is not a water cut I THINK.
As cold water enters the heater. its heated by the pilot flame, and takes a while before u have total hot water? what do u mean by cuts off? perhaps u have a pilot heating problem due to it going or coming off and on? are there any air drafts around the heater?
has this heater always acted like this? if so
you need to supply heater with the right water pressure or flow
try cutting back by turning inlet valve off to restrict flow or restrict flow on hot end. hope it works it did on mine
Add a comment for more free help. Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
You have 240volt electric water heater Check both elements for leaking. Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture. This tank must be replaced. http://waterheatertimer.org/Water-at-bottom-of-water-heater.html My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands. If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF. This causes major damage inside home.
Protect yourself first, and then let's talk more. 1) Turn off water at shut off located on cold water line above tank. 2) Turn off power to water heater: Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON. Electric heater, turn off circuit breaker. 3) Open tub spout on hot side and let run a bit to relieve pressure. 4) Now your property is safe.
You can limp along with failed heater if leak is slow. Turn heater ON when you need hot water. Typical Gas heater makes 41 gallons hot water per hour. Typical Electric heater makes 21 gallons hot water. Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water. http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself: Look at label on side of old tank to identify size and particulars. I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed. Buy same size heater if it worked fine before. Buy new flexible water connectors. Set water heater in drip pan. Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too. #1
rule) tankless heaters are a rich-man's toy, because tankless will
never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption) 2) How to install gas heater: http://waterheatertimer.org/How-to-replace-gas-water-heater.html 3) How to install electric heater: Read link above because many of same steps apply to electric. The
difference with electric, is turn off power, disconnect wires, and
reconnect wires exactly like before. Set electric heater directly on
insulated surface like dense blue styrafoam. Cut styrafoam in circle
so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve. 4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Add a comment for more free assistance. Also take advantage of fixya phone service. For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
