Question about Acer Aspire 3000 Notebook
How to connect laptop to tv
I CONNECTED MY LAPTOP TO TV WITH VGA TO RCA CONNECTOR AND NOTHING HAPPENED.WHY I DID NOT GET PICTURE ON TV?
THANK YOU
  • mrkogers Feb 22, 2009
    I connect my Acer 3000 laptop to my Sony Bravia HD TV and it displays for a short time during boot up but then switches back to the little laptop screen. I would like to play NetFlicks movies on my PC and display them on the Bravia with both picture and sound. Is F5 my ticket home with the fifteen pin cable and audio jack?
F3 keys is the one!
Posted on Mar 05, 2008
  • 589 Answers
You should be ably to toggle the output between the LCD and the output jack by pressing the FN and F5 keys.
**note** check your F keys for a picture of a little monitor, as F5 may not be the correct one for your model.**
Posted on Jan 16, 2008
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Hi, could you tell me how/if i can connect my Acer Aspire 5742 laptop to my televison please, Thanks Alix
Hopefully your laptop has a VGA output, if you do not know what that is there is a link below:
http://www.computertroublesolver.com/image-files/laptop-vga-connection.jpg
Now check to see if your tv also has a VGA output most modern tv's do now, if it does buy yourself a VGA cable but with both the same connectors at each end then just plug one side into your laptop then the other into the TV.
if not buy yourself a vga to rca cable which look like this: http://networkcable-tester.com/wp-content/uploads/2011/03/vga-to-rca-cable2.jpg
hopefully your tv does have an rca output.
here is where you can by a VGA to VGA cable quite cheap: http://www.amazon.co.uk/gp/product/B002N2KY54/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=103612307&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B000WTT0EG&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=1K0C1AGYT9XC9CHTQ1KV
here is a VGA to RCA cable : http://www.amazon.co.uk/1-8M-VGA-LEAD-CABLE-LAPTOP/dp/B000P3NZ68/ref=sr_1_1?s=electronics&ie=UTF8&qid=1310838406&sr=1-1
Hope this helps.
Jul 16, 2011 | Acer Computers & Internet
Want to know how to connect acer 3680 to tv
It depends on your TV
If your tv has a Computer VGA connection you can directly connect the VGA connector from the left side of the laptop to the connector on the tv
If there isn't then you could go buy a S-Video to RCA cable at radioshack and connect the S-Video port on the laptop to a video in connection on the TV
For sound you can connect the speaker/headphone jack on the laptop to the tv using a cable either going direct from 8mm to 8mm or from 8mm to RCA...either can be found at radioshack
Let me know if you need anything else!!
Jul 01, 2011 | Computers & Internet
What is MAxmedia tv for?
its a VGA to s-video/composite(rca) converter. it allow you to connect a computer to a tv with compatible inputs. Example would be to connect your laptop to a tv to show videos or pictures at a family gathering. you connect a VGA cable to the VGA output on the laptop(usually blue) connected to the MaxMedia TV II Plus, then from there you could connect a set of rca to the tv and view whatever the laptop sees on the tv screen with audio.
another example with a diagram
hope this helps
Apr 18, 2011 | Umax MaxMedia TV II Plus (MTMD-83611)
How do i connect my laptop to my television
You need a VGA to TV cable. If your TV has a component input, you need a VGA to component cable, like the following one:
http://www.amazon.com/Male-3RCA-Component-Video-Cable/dp/B000SJ2TJ8/ref=sr_1_9?ie=UTF8&s=electronics&qid=1266279733&sr=8-9
The VGA connector is for your laptop (you connect in on the side) and the RCA connector (3 plugs) is for your TV
Check your TV for a green, blue and red connector on back.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 16, 2010 | Toshiba Satellite L505ES5015 NoteBook
How can I connect my Toshiba Satellite A305-S6872 laptop to my TV?
Check your notebook for "S-Video / TV out" port that has a 7-pin jack instead of a standard 4-pin S-Video jack. Check your laptop before ordering this adapter.
The newer your computer is, the better chance that it comes with either a RCA Composite or SVIDEO connection. Some notebook computers also have video outputs on them. When buying a new computer always look for the words "TV out" or "video out" in the computer description.
If you only have a VGA connector and don't have an HDTV then your best choice is to buy a newer video card with an S-Video connector. There are other third party solutions out there but the quality is very poor and we do not recommend it.
The VGA port is the connector that's connected to your PC monitor (the TV like device that came with your computer). This connector is usually only usable for VGA Monitors or HDTV setups. If you have an HDTV this will give you the best image possible.
If you have an RCA Composite connector on the back of your computer, then you can use that. You may also need to power down your computer and reboot to be able to get the signal. You need an RCA Composite cable that will be long enough to reach from your computer to your PC. Connect the cable to the back of the computer to the back of your TV SET.
S-Video is superior to that of RCA Composite and will give you a clearer picture. If you have a fairly new TV you should have this connector in the back. You will need to buy an S-VIDEO cable, which you can buy just about anywhere you buy home video products. Connect the cable to your S-Video on the back of your computer and then connect it on the back of your TV
Jan 01, 2010 | Toshiba Satellite Laptop
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
How do i hook up a T5230 E Machine with no RCA port to A Emerson 32in Hd Tv with no vga port?
  • http://www.eforcity.com/pothvgasvrc1.html?gad=CNGV0_4CEgjzLnO-zCySDRiJp-j9AyDV7too
  • VGA to S-Video / RCA Adaptor
  • NOTE: Your VGA card must support TV out directly through VGA port function. Please consult with your VGA card's user manual for more information.
  • Cable adapter allows video output from your PC/laptop to any TV with S-Video or RCA video input.
  • Connectivity:
    • Connector HDDB15 15-pin (M x 1)
    • Connector S-Video mini din 4-pin (F x 1)
    • Connector RCA Composite (F x 1)
You can find several like this from 5 to 10 dollars , just search the phrase "VGA to RCA cable"
yell if you need any more help and thanks for using fixya. ------please rate-------
Oct 22, 2008 | Computers & Internet
How do i hook up a tv monitor to my campaq computer
usually laptops have vga conector for external display, you may need a cable, vga cable.
vga cable varies depends on the connection that you have on the tv, if your tv supports vga connectors thats great, some tv doesnt have that option, thats where adapters go in to adapt what ever ports or connections you have on your tv.
some of the cable adapters that you might need.
vga to hdmi.
vga to rca.
vga to dvi.
hope that helps.
Oct 17, 2008 | HP Compaq Presario V2000 Notebook
Connecting laptop to TV using Composite Video ? RCA connector
Research to see if the tv is vga compatable. Not all tv's can be hooked up to a computer. Most tv's that can be will have a vga port, thus you will need a vga cable.(sorry don't have a pic, google it)
May 19, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire 3000 Notebook Logo
874 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
