Question about PC Desktops
Hi folks!! My mi optical mouse often has windows rolling and scrolling in a rolling motion over the page. The scrolling is hard to stop!!! And the rolling motion of the page is most annoying! Any thoughts how to ameliorate this problem? Many, many thanks in advance!!! I have another problem and that is though Adobe Flash Player downloads into my Linux Redhat/Suse Operating System, I cannot use this program, it just won't work, and this disables my ability to IM on Yahoo and on a dating site and to view streaming videos that I get in emails and the like!!! This is most disturbing and frustrating too!!! Any help that you could offer would be sincerely appreciated!!! Thanks again greatly , in advance!! VK , NJ
  • 1,142 Answers
Re: Hi folks!! My mi optical mouse often has windows...
Please downlaod adobe flash player 9 in case you are using an older version. it should work.
Posted on Jan 17, 2008
0 characters
3 Points
Cant scroll on facebook
Check your mouse scroll because mouse help you scroll any page. If possible change mouse. Or if your PC hung may be not scroll.
Computer Support
Feb 13, 2014 | Dell PC Desktops
How do you buy a Bluetooth Mouse?
<p>Bluetooth wireless mouse is still a very popular choice, especially for laptop users and travelers. It gives you the freedom of cable and Bluetooth connectivity. See how to buy. <br /> <p><br /> <p>1. Make sure your computer has a built-in Bluetooth receiver to detect the Bluetooth mouse. <br /> <p><br /> <p>2. Check if your mouse supports Bluetooth 2.0 or higher technology. <br /> <p><br /> <p>3. Meet different tracking technologies and differences. A mouse is old-fashioned mechanical mouse, a tracking ball on the bottom. This function allows the rollers inside the mouse to move. A new version of the same technology, optical mouse sensors. <br /> <p><br /> <p>4. Understanding optical mice. An optical mouse uses a beam of light that is controlled by an optical sensor to detect motion. Unlike the mechanical mouse, which requires little maintenance and no risk breaking parts. <br /> <p><br /> <p>5. More information about a laser mouse. It is the most advanced tracking technology and is a progression of optical mouse. Unlike the broad beam of an optical mouse, laser mouse uses a narrow beam of light sharp. For you, this translates into higher accuracy. <br /> <p><br /> <p>6. Consider the number of mouse buttons have. Typically, the two buttons. Some offer more advanced mouse buttons, which can be programmed for specific actions. <br /> <p><br /> <p>7. They prefer a mouse with a scroller. This makes navigating through pages much easier. <br /> <p><br /> <p>8. Consider the size of the mouse. If you are a frequent traveler, choose a little mouse that is easy to carry. <br /> <p><br /> <p>9. Get opinions from online guides such as Epinions or My Simon. <br /> <p><br /> <p>10. Compare prices of your local retailers and online stores. Many online stores offer Bluetooth mouse at a lower cost. <br /> <p><br /> <p>11. Online trust an online store or you can place your order directly to the site of the brand you choose. <br /> <p><br /> <p>12. You can also buy from a local store. <br />
on Jun 26, 2011 | PC Desktops
How to fix how much the wheel scrolls
If you are a windows user then follow the below steps:
Click on Start Menu
then select Control Panel
in the control panel select the Mouse option
and when you double click on Mouse a new window will pop up
on that window click on WHEELS
and there you can set the desired scrolling with mouse wheel.
Thank You
Aug 28, 2012 | E-Machines PC Desktops
Hi, I have a problem with the scrolling bar at the right side of the page, when trying to scroll up & down the page it stops & you have to wait about 30 seconds then the bar gets smaller & it...
This problem of your computer is not due to mouse, i believe your computer is responding slow due to some reasons:
1. Lot of application installed on it, do uninstall software you dont want. 2. Clean the temporary file from your computer 3. Check and Remove hard disk errors 4. Check and clean virus/spyware
You can get helps from this web site as well
Hope this helps, if so do rate the solution
Jan 06, 2011 | Dell Inspiron 530 PC Desktop
Page by Page Scrolling
Bad scroll wheel on your mouse?
Nov 01, 2009 | PC Desktops
Internet Explorer page stability
If your mouse isn't acting funny while using it in any other applications, you can either try uninstalling internet explorer and reinstalling it, or try using different browser such as Firefox
Mar 12, 2009 | HP Compaq Presario S4000V (P8655P#ABA) PC...
HP Optical Mouse Curser jumps around
I respectfully disagree with amusedgeek. He is correct aout the textured surface,though.Optical mice will take snapshots many times a second and reposition the cursor according to where the pattern was last. Rather than a single color, a pattern is your best bet for an optical mouse. The only thing I recommend is to make sure the mousepad isn't reflective at all- no glossy or semi-glossy surface. You want it to be non-reflective. Just to be sure there is nothing wrong with the mouse, you can test it simply by putting it on a newspaper and scrolling around.
Jan 11, 2009 | HP PC Desktops
Mouse, cursor and scrolling problems
Dec 03, 2008 | HP Pavilion Media Center a1330n - AMD...
Mikomi/USB optical mouse has started scrolling problem like page refreshing each movement of scroll wheel and if a large movement is made,pages wont stop "refreshing." XP home software,service...
Solution found by altering the screen resolution, this brought the mouse under normal scrolling control
Thanks for your time
A Brownless
Nov 22, 2008 | PC Desktops
I cannot adjust the way my mouse scrolls. My hard drive crashed and I have a new hard drive but since getting it back my scrolling on a page is very jerky not smooth the way it used to be. I have a...
Use this page to find the latest logitech software for your mouse.,en
Jul 15, 2008 | PC Desktops
PC Desktops Logo
69 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
