High blue ics bad
Is this some thing a handy man can fix or do you need special tools , and or were to get parts for toshiba
  • shawnm23 Jan 17, 2008
    61h70
  • Anonymous Jan 22, 2008
    witch part # do i need to order for this problem. model 61h70 toshiba. blue color is not in line it is higher then rest. thanks shawn
  • 8,617 Answers
If you can solder you should be able to fix it without any difficulty. What model toshiba do you have?
Posted on Jan 16, 2008
  • Sonny Berry
    Sonny Berry Jan 17, 2008
    You can get your parts at this link. The ICs are about 6.99 each. You will need 2 depending on your model, you will also need heat sink compund when you mount them.
My 2005 magnavox 20mc4304 has a green halo around the perimeter of the picture. is this something i should be able to fix if i am reasonably handy, or does it require special tools?
That usually indicates the panel is going bad. You could fix yourself, but the part is around 90% of what you paid for the tv. I wouldnt work on the tv because it holds high voltage even when unplugged. Hope this helps.
May 25, 2011 | Televison & Video
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Toshiba 57h84 sounds like it is turning on but the only thing it is doing is the red light on the power button flashes no sound on picture nothing
CK your hori output Transistor and small blue capacitor round it feed the hori output 2k high voltage cap if they are OK then Replace both of your STK ICs they will have part number on them. For Parts Call Mats 1-800-628-1118
Dec 08, 2009 | Toshiba 57H84 57" Rear Projection...
Toshiba 60HX70 distorted picture, blinking red light
You could have a Power Supply Regulator Problem. Many times these sets will not hold Horizontal sync when there is excessive High Voltage or a problem with the High Voltage Regulation. This is not a problem you want to deal with yourself. I would recommend a Toshiba Repair Facility to come out and diagnose it.
Hope this helps,
Skyassoc
Jul 22, 2009 | Toshiba 61HX70 61" Rear Projection...
Powers steering or power steering hose problems
Honestly the best thing is to take this to a Handy man with the tools and knowledge or take it to your local repair shop and let them fix your proble!! This is a system that is under high pressure and something that i would second guess with!! Requires special tools to fix this issues
Dec 07, 2008 | 2005 Kia Amanti
Sony kp51ws510
How much do you know about electronics and can you solder? There is 1 sure way to find out if high voltage splitter is bad disconnected the Flyback transfomer from it /If set comes on and stays on splitter is bad.Make sure you place high votage lead from flyback where it cannot shock you.or short out anything near chassis.Also check little round blue capacitor behind Hori output they go bad 1200pf 2kvolts. This set i think has 2 STK392-??? big black ics if one of them is shorted set will not come on.Its up to you on fix or throw away
Sep 04, 2008 | Sony KP-57WS520 57" Rear Projection...
Convergence ICs - Toshiba 57h81
they send the instalation instructions with the ICs , which tells you what tools you would need and exactly how to replace them. yes both Ics should be repalced together as they work together to control the 3rd color. yes STK392-110 are the correct ICs for your model.
Jun 20, 2008 | Toshiba 57H81 57" Rear Projection...
Color convergence alignment
change your convergence ICs that should solve your problem.If you need more info let me know.
Apr 08, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 55H81 Blue and Red Only
so you missing the green is is either a bad connection on the green crt or convergence amp ic bad
do this first
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
then if that doesnt fix it
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 23, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
