Question about Dacor Preference PGR30SS Gas Kitchen Range
REALLY long to preheat ...
I recently bought a used Dacor PGR30SS (gas and convection) from a homeowner. The person I bought it from had just moved into a new house and didn't like the oven b/c she said it took a really long time to preheat.
She wasn't kidding. Started it up last night at 7:49pm, set it for 400 degrees. At 8pm the internal temperature hadn't risen above 135. Finally at 8:30 on the dot the oven beeped to let me know it had reached 400 degrees.
I realize I should first do a temp check to make sure the internal thermometer is actually not the issue, and plan to try to do that tonight. But any other suggestions?
  • feldmanm Mar 23, 2008
    I have a similar problem. Usually take 30-40 mins to preheat
I had the same problem; replace ignitor
Posted on Mar 10, 2009
Oven turns off without warning
I had to replace the thermo coupler in mine. Would heat up then go out.
Aug 17, 2014 | Dacor Epicure ERD30 Dual Fuel (Electric...
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Pgr 30 oven takes a long time to heat up
Hot surface Ignitor is bad most likely. Normal wear and tear. You can check it by looking at it, it should be black. If it's white, it's no good.
Dacor oven repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Dacor Preference PGR30SS Gas Kitchen Range
Is the hot surface ignitor supposed to stay on all the time on my PGR30SS? My oven takes a long time to heat up.
( yes) most ovens that use hot surface system stay on during heating . if its weak is orange glow instead of white hot . this would cause slow heat up / hope this helped ****
Dec 04, 2009 | Dacor Preference PGR30 Gas Kitchen Range
Dacor oven overheating
sounds like your bake relay is not closing
you need service relay board replaced
Aug 01, 2017 | Dacor Preference PGR30SS Gas Kitchen Range
Dacor rsd30 celsius to farenheit conversion
Choose the Convection Bake Mode on your controller and select a temperature of 500 degrees or higher. Press and hold Convection Bake for 3-4 seconds and "F" or "C" will appear in red in the display. Using your up/down keys, toggle from "F" to "C", or "C" to "F" depending on your choice. If you hare not using your product, turn it off by pressing Cancel/Secure
Feb 21, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Oven lights won't work
its possible but its also possible no current is flowing through the relay you are hearing.
Dec 07, 2007 | Dacor Preference PGR30SS Gas Kitchen Range
Dacor Preference PGR30SS Gas Kitchen Range Logo
380 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
