Question about Philips Epic 15PF9936-37 15" Flat Panel LCD Monitor
15PF9936/12 Flat TV
I get a picture for a few minutes then the picture disappears and I am left with only the sound. Then after another few minutes the sound goes also and all I am left with is a blank screen.
AB
  • ert7 Jan 29, 2008
    i have the same promlem what should i do?
  • ghost85 Jan 31, 2008
    In my case I get sound but no pictures. Philips tech support was useless.
    I tried unplugging the power adaptor leave it off for 20 secs (resetting). Sometimes that works, other time it does not.
    Scholar:
  • 21 Answers
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
Check the small fuse on the underside of the board that is the high voltage drive for the CCFLs
Posted on Apr 05, 2009
I have a Sharp Aquos tv which repeatedly turns itself off. Can anyone help?
Try going into the menu on the control and change the power saver off, or the sleep programe turn them all off.
Mar 23, 2012 | Sharp Televison & Video
Turn on picture and sound are great. for about 60 seconds. then the picture disappear but sound is great. turn power off wait a little bit ( try differ times. from 15 seconds to 10 minutes) Turn back...
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 16, 2010 | RCA L32HD32D 32 in. LCD HDTV
Tv turns on, picture disappears after a few seconds, turn off tv, and then on, same problem picture is fine, the disappears after a few seconds
You may have either failing 24vdc power supply or the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Televison & Video
TV screen tuurniing on and off, sound remains on.
If its a DLP set have you ever replaced the lamp? If not I would suspect that first..
Aug 14, 2009 | Televison & Video
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Picture loss!
It sounds like cold solder joints on the vertical IC chip. Not a major deal. The entire board should be looked over for other joints becoming cold.
Mar 12, 2008 | Toshiba 35AF44 35" Rear Projection...
Very faint picture but sound is fine on my 50" Zenith plasma
Sounds like the Z-sustain board went bad. You will need the board replaced so make sure you find an LG authorized servicer.
Dec 02, 2007 | LG 50PX4DR 50 in. Plasma TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Philips Epic 15PF9936-37 15" Flat Panel LCD Monitor Logo
638 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
