Question about Sony MEX-BT5000 CD Player
Sony Car radio cd bt5000 with US steping !!!!
I have a sony bt5000 with us fm steping mode , is there a way to change to european so i can receive fm stations from europe ,
any advice is welcome
  • rafdg May 13, 2008
    I have same problem. Please help me.
  • michros Dec 28, 2008
    i dont think so, there sould be any possibility ti change this because i found jus a sec before that it's possible in sony mex bt2500 - i found service manual for bt2500 and they worte there:
    Frequency select switch
    The MW (FM) tuning interval is factory-set to the 9 k
    (50 k) position. If the frequency allocation system of
    your country is based on 10 kHz (200 kHz) interval, set
    the switch on the bottom of the unit to the 10 k (200 k)
    position before making connections.
    Note
    If the switch was set with power supplied to the unit, disconnect
    the power connector from the unit, wait for 20 seconds, then
    reconnect it.
    Tommorow i'll look for that swich in my bt5000, hope it'll be on the radio :) And now i'm starting to find service manual for bt 5000
    Sergeant:
  • 300 Answers
I don't believe this is a user adjustable setting (at least it's not documented). Chances are, it is set within the firmware of the unit itself. Versions of this deck sold in Europe probably have a different version of firmware, allowing 0.1MHz FM increments. You might be able to talk to the European arm of Sony's support and ask them about updating the firmware to the latest European version. Keep in mind, putting EU firmware on a deck that was supposed to be used in the US could cause problems.
-=Zzed=-
Posted on Mar 04, 2008
6ya staff
SOURCE:
I have bought jbl on time 200P dock station for ipod with radio but all the freq in radio is odd numbers and i need to change it to even numbers
Hi. Try this: change your language settings to a European language. After that you can choose your radio type: choose Europe. Exit the menu. Now you will be able to choose radio stations with two decimals, for example fm 88.15. I hope this solves your problem.
Sep 05, 2011 | JBL On Time 200iD iPod Dock/Clock Radio...
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
I am having KEH-P8900R/X1B/EW PIONEER, by default it is playing the radio station FM- AF, I am trying to change it AM, but I did not get sucess. Can you please advice, how to change it. Thanks &...
There should be a "band" button on the stereo. you may have to press it several times before you get to AM mode, depending on how many FM stations it will store in it's memory.
Mar 25, 2011 | Pioneer KEH-P8900R Cassette Player
Is there option to switch FM stations scanning to europian standard - 5kHz step?
there is an ic chip that generates the divide by n .that ratio determines the scan.you can check the european counterpart and change the ic
Jul 14, 2009 | Sony CDX-GT520 FM / AM Receiver
Is it possible to change from US fm to european fm radio?
this would involve basically gutting the Bose and replacing the circuts with the European market equivalent. however, since a bose contains Propriatory Hardware, it may have denied internal access. I suggest you locate a CE approved version.
Jun 11, 2009 | Bose Wave Radio II
USA - EUrope FM band stations frequency differences
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it will not pick up many European radio stations. This is due to the fact that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
Jun 11, 2008 | Kenwood KDC-MP2035 CD Player
Region problem
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
Jun 09, 2008 | Kenwood DNX7100 Car Video Player
Very weird Radio Tuning Problem
This is a USA model and by default in the USA all FM stations end in an Odd number. This is completely normal. you can try holding preset 1 and 5 down while pressing the reset button on the unit and it may allow you to switch to a Europe style of tuning.
Oct 10, 2007 | Kenwood Sirius KDC-MP522 CD Player
Sony MEX-BT5000 CD Player Logo
316 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
