Question about Dell E173FP 17" LCD Flat Panel Monitor
Replacements for lighting inside monitor
I have a Dell E173FP 17 in. Flat Panel monitor and need to replace the light tubes in it. Where can I get them?
    Novelist:
  • 138 Answers
Measure the length of your screen or the old tube and get these from ccfldirect.com or moniserv.com . measure the diameter from the old tube, Just be close. Good luck!
Posted on Feb 07, 2008
I have a Dell E173FP 17 inch Flat Panel LCD Monitor. About two weeks ago after having turned it off at night (leaving the PC on) then turning the monitor back on in the morning it would light up to half of...
The monitor can be repaired - by replacing one or both the fluorescent tube and inverter. You can have the work done for you - or you can attempt it yourself. Lamp prices vary based on size - but most hover in the $10 range. Inverters can vary in price too - but run more than lamps for the most part. There are numerous suppliers for these parts such as this and instructions about how to do it such as this.
I hope this helps! Please rate my reply - thanks!
Dec 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Computer monitor all black but power is on.
Check to see that monitor is turned on, power cord is connected. Check to see that video cable is connected to computer. Verify that monitor's power light is on.
If it's still black with power on, you may have settings that have to be changed on the monitor.
Go here: http://support.dell.com/support/edocs/monitors/E173FP/En/trouble.htm
Aug 03, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Black screen, power light flashes green
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 28, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
DELL E173FP 17 IN. FLAT PANEL
try to find on ebay base that you can fix at the back of the screen where there is the wall fix
Jan 17, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
19 in Dell flat panel monitor
also need to see video how to remove back of monitor case
May 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Goes out
Please list the model number of your monitor.
Also is the power light flashing? What color(s)?
Unfortunately the symptoms you are describing tell me the inverter/power board inside your monitor needs to be replaced.
Mar 05, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
82 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
