Question about RCA D52W136D 52 in. TV/DVD Combo
TV RCA SCENIUM D52W136D 52in
My tv when turned on, cuts right back off and on again by itself a few times before permanently cutting off. Also when its first turned on, the screen is green. This happened over a year ago as well but the screen was just blue. I think I had the driver replaced at that time, cant really remember. My question is, could the driver had gone bad already or could this be something else?
  • Ron Harris Jan 18, 2008
    I had the video driver replaced over a year ago. Having a tech come to the house this friday to look at it for $60 (will you take a ten?) Hopefully its something simple, quick to fix, and very inexpensive ;-)
  • Anonymous Sep 01, 2008
    RCA Scenium Model D52W136D purchased June, 2004 won't turn on. Sometimes if you turn it on 3 times in a row, the blue light comes on and off 3 times at 10 second intervals, then it won't come on pushing the power button until about 55 seconds later. Then it comes on and off for about 8 seconds 3 times, again goes off and won't come on again for about 55 seconds. This cycle persists for about 10 sequences and then finally the TV has been turning on until yesterday when it would not turn on with about 30 cycles.
I have akai LCD HD TV , when i turn on i have audio but screen has a pink or green or white lines, is this a major problem to fix or is it a quick fix?
Posted on Jun 01, 2008
Problem solved, it was my green driver this time and only $25 to replace.
Posted on Mar 28, 2008
Sanyo dp50747 glitch, cut on it will cut off
Sounds like a power supply regulator board fault. If the supply output from it is not normal, this kind of fault can occur. Contact any service technician. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 09, 2013 | Sanyo DP50747 50 in. Plasma TV
Screen and sound cuts out at times.
I would check the power board capacitors. Many people are losing the electrolytic caps on these boards. It is possible yours are failing only when they heat up.
Apr 13, 2013 | Televison & Video
My tv keep cutting itself off. I will have to
It could be going into power saving mode. Check your settings.
Hope this helps.
Iain
Oct 14, 2009 | Computers & Internet
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
My JVC AV-48WP30 picture is distorted vertically to about half the screen height. If I turn the tv on and off a few times, sometimes it will correct itself, until I turn it off again.
Try resoldering the vertical output IC that should correct the issue repeated off and on cycles often tend to bridge the solder connection causeing the set to work untill power is cut off.
May 15, 2008 | JVC Televison & Video
RCA D52W136D 52 in. TV/DVD Combo Logo
650 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
