Question about Dictaphone Walkabout 5210 Digital Voice Recorder
Dictaphone 3720 Transcriber will not play or record
Dear Reader:
The only thing the cassette will do is move fast when you press the Fast Forward button and when you push Rewind, it rewinds very sluggishly. It will not Play or Record on the cassette tape.
Any suggestions?
Thank you
  • 43 Answers
Re: Dictaphone 3720 Transcriber will not play or record
All three problems could be related to drive belt issues. Either the belts have become stretched-out or have broken.
Posted on Mar 13, 2009
0 characters
3 Points
I have just bought a Dictaphone express writer 1740. It rewinds and fast forward but does not play properly. It is in excellent condition. We are using micro cassettes. The manual said this machine can...
This unit takes mini cassettes, not micro. A common issue with the playback on this model is the rubber tire on the drive reel cracks, causing it not to turn. It probably needs to be replaced.
May 08, 2011 | Dictaphone 1740 Desktop Cassette...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Dictaphone transcriber 3750 won't play, reverse, or go forward. What can I do?
Does anything show up on the display? Like 'No Cassette' or 'End Tape'?
Are you using a foot control? Does the tape move when pressing the buttons on the machine itself? Is the foot control plugged into the side of the machine (and NOT the back)?
Feb 18, 2010 | Dictaphone 3750 Desktop Cassette...
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Dictaphone 3750 transcriber
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
Sep 09, 2008 | Dictaphone 3750 Desktop Cassette...
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Nov 04, 2007 | Dictaphone 2740 Desktop Cassette...
Just had the same problem!!! You have to press FF and Play at the same time to stop the fast play!
This is probably way overdue and you won't even get it, but just in case someone else has this is the answer!!
Sep 19, 2007 | Dictaphone 2740 Desktop Cassette...
Dictaphone Walkabout 5210 Digital Voice Recorder Logo
290 people viewed this question
Top Dictaphone Voice Recorders Experts
David Burkhart
David Burkhart
Are you a Dictaphone Voice Recorder Expert? Answer questions, earn points and help others
