Question about Samsung Digimax S730 Digital Camera
Card Error When camera is turned on it displays "card error" on screen
  • Cherylbtc78 Sep 22, 2008
    When I turn on my camera, sometimes it reads "card error". What can I do to fix this problem?
  • adi0sk88 May 11, 2010
    Take the memory card out and see if it works without the card, if it does then get a new memory card to see if your memory card is bad. That happened with mine and the card just went bad for some reason.
  • 20 Answers
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Posted on Sep 14, 2008
Memory card error displayed
There is a little slide switch on the side of the memory card. Good luck!
Nov 25, 2007 | Canon PowerShot A410 Digital Camera
Error 30
The "E30" error code is displayed when reading/writing data on a storage card has failed. Especially, the error code "E30" may appears when you tried to remove a storage card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another storage card. If you have another storage card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the storage card with your camera Try to format the storage card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a storage card will erase all data on the card. Once the storage card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the storage card. If turning the camera off and then on again, and then performing steps 1 to 3 above fails to clear the error, a camera malfunction may have occurred. Please contact the retail store where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a storage card: - Do not remove a storage card or turn the camera off while the camera is recording, loading, or erasing data on a storage card. - storage cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a storage card. - Place the storage card in the supplied case for storage. - Moving a storage card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the storage card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condens
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
The camera screen displays a "Memory card requires formatting" error message. What should I do?
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Memory card is full"
This error message indicates that there is no more space on the memory card in the camera. To resolve this problem, do one of the following: Turn off the camera and insert a new memory card. Transfer or delete pictures from the memory card. Change the storage location to use the internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
"No memory card (Files not copied)"
This error message means that there is no memory card in the camera. Pictures were not copied. Turn off the camera, and then insert a memory card.
"Memory card is locked
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
The camera screen displays error message
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Samsung Digimax S730 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
