SoundLab SP500 Amplifier
I have a SP500 amplifier that needs fixing as a favour for a communial centre, they had put two speakers into one output. Two of the main mosfets blew in the full bridge circuit. I replaced them but only got sound from one channel, but then the other two blew. Is there a special way to set this amp up when replacing the mosfets? I noticed a pot that could be adjusted, but without a circuit diagram I'm stuck. I do have access to test equipment.
Any help appreciated.
Thanks.
  • 1,512 Answers
I strongly recommend that you replace all output transistors at once, and the drivers also. Also look for arcing across small low value resistors about the output stages, and small signal diodes also for 0.6 volts barrier potential voltage(they often go short circuit also). soft start the amp with a variac if you have one, or an incandescent 60watt 240v(110v if in the US) lamp in series with mains power to limit the current that can flow to protect the amps circuits if there are still faulty parts about. Check
DC conditions everywhere you can. If both channels appear to be ok, Then some careful observation of voltages with a DMM will help you to find any more problems.
Amps by design with high potentials and direct coupling ascociated with DC feedback loops, make this sort of work hard to do even for an experienced tech as it is very easy to damage the parts you have previously replaced if you do not check things well enough before firing the unit up. Softstarting with a variac or some sort of limiting in the power supply are generally the safest ways to approach this sort of repair. If you dont think you are up to it, refer the work to an experienced audio tech, or hitme back here and I can assist you if you wanna have a crack at it. Cheers. A "fixya" rating would be great for my 2 cents worth here. :)
Posted on Jan 19, 2008
I've got one on the bench at the moment which has all four output devices shorted on one channel - I found this site while looking for a schematic without success. I've traced out the main elements of the circuit so I can understand it better and I can tell you the trimmer is to set the standing bias current on the output stage ( this should be about 40mA, measured where the positive fuse would go if the amp was working OK ).
This is a pretty awful circuit, using all N type Hexfets, ( IRFP240 ) which shouldn't really be used for audio at all. I assume it's just for cheapness. These devices are notorious for thermal runaway, so make sure you keep the ventilation clear when you rebuild it and make sure the fan works properly.
I agree with the advice about 'soft-starting' the unit - especially if you haven't replaced all the other devices at the same time. I use a couple of 40Watt light bulbs wired across some old blown 20mm fuses so I can quickly insert them in the circuit of anything I'm repairing.
They only drop a few volts if the circuit is OK, but they limit the maximum current to half an Amp or so if there's a problem. That's usually enough to let you turn it off before the smoke gets too bad...
Obviously, they'll do the same if you try to drive a signal through the amp once it's fixed, so it's best to check the circuit with a line-level sine-wave signal and an oscilloscope with no load to make sure the waveform isn't clipped or distorted before you fit real fuses and connect a dummy load.
The signal test should then be repeated so you can check the current drive is OK. It's also handy on the Soundlabs to check the 'PEAK' indicator lights just below the level where the signal gets clipped. Driving speakers with a clipped signal greatly increases the power they receive and is the biggest cause of early failures.
Hope this helps, Graham.
Posted on Mar 24, 2008
Need help putting in stereo for a 1998 toyota avalon xls
hook speaker wires to the amplifier output, can't use from the radio wires because they used a not smart design using one wire output from radio to amplifier, the amplifier output is connected to your soeakers, a simple check, use 1.5 battery to speaker and check the speaket, should move, or hook to some cd player output, easier that way
Jan 01, 2014 | Toyota Avalon Cars & Trucks
Good afternoon, I recently bought a SA VE325 speaker set it contained a subwoofer, 4 little boxes and a mid-large box which you haeb have tpo piuyt above uyour tv. Now the problem is we have no cCENTER to...
Hello there looking at the manual i would assume that the mid-large box is actually your centre speaker.
Did you mean that there are no connections left on the back of your amplifier? For a centre speaker this system uses all passive speakers apart from the subwoofer which has a built in amplifier for just the subwoofer, your hifi or home cinema amplifier would need to have at least 5 separate channels to operate the centre speaker as well as the front and rear speakers.
Ideally you would need a 5.1 channel or 5 channel amplifier with subwoofer pre output, any would do but to make things simple one with a digital optical or coaxial input would be best as this can easily carry multi-channel audio with just one connector.
The other alternative if your amplifier does not have a centre speaker output are:
· to get another basic mono stereo amplifier to power the centre speaker on its own however if your main amplifier does not have a pre out connector for a centre speaker you will have to change the volume independently on both amplifiers
· don
Aug 27, 2011 | Sony SA-VE325 System
I have a brand new logic soundlab tx1002. it was hooked to a brand new radio and new speakers. When turned on, it is in protection mode. you get a popping sound from the speakers. we have checked all...
first disconnect one wire at a time, making sure the power is off. then connect power and check to see if your speakers are making the popping sound. when you do your speakers, make sure you disconnect both positive and negitive of each speaker at one time. when your amp goes out of protect mode you will have found your suspect wire. then trace to the issue. it could be as simple as crossed over possitive and negitive wires
cheers
Jan 11, 2011 | Logic Soundlab LSX2600 Car Audio Amplifier
What is the hi input for
Hi input is for smaller speakers...not subs....
Oct 05, 2010 | Logic Soundlab ALX280 Car Audio Amplifier
Logic soundlab plx 46 red led lit in center of board what does it mean?
does it have sound if not it may be on a protect or themal mode try taking our=t your main fuse when the system is in and put it back in
Dec 17, 2009 | Logic Soundlab PLX-520 Car Audio Amplifier
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
Is that ok to do mono on Thump TA1001
yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
Let me know if you need any more help,
Dave
Aug 08, 2008 | Thump TA1001 Car Audio Amplifier
Amp fuse
There are two 40 amp fuses in the unit I have.
May 19, 2008 | Logic Soundlab CPX1820 Car Audio Amplifier
Amplifier in home system - only one speaker working
is your wireless microphone only a mono signal? if so, thats why your only getting output on one channel regardless of amplifier used.
Apr 19, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Mar 31, 2008 | Logic Soundlab PLX-520 Car Audio Amplifier
1,359 people viewed this question
 Grubhead
Grubhead
