Hard disk clicking
I am trying to recover data by connecting my old PC hard disk through an external caddy. It only makes a clicking noise which I presume means that it is dying or dead. Is there anything I can do. Is it worth opening up the disk?
  • 589 Answers
Opening up the disk will render it unless you have access to a 'clean room' - which most of us don't.
However, I've been able to get 'clicking' drives to work by repeatedly connecting and reconnecting it to the USB and / or power source.
Sometimes it will 'catch'. Sometimes a nice 'tap' on it helps too.
Most of the time, it's spacejunk though.
Posted on Jan 17, 2008
Is it possible to recover data from the disk inside the external hard disk?
See first this clicking sound is not good in terms of hard drive failure as continuous clicking is one of the symptom of hard drive failure.
Secondly you have tried to do something with the hard drive by your own that you should not as it is always recommended that you should not open your hard drive in any open environment except Class 100 Clean Room Labs that is only available with Professional Data Recovery Company.
This is recommended because opening the hard drive in an open environment can damage your hard drive severely thus it reduces the chances of successful data recovery from the hard drive.
Now if your data is really very important then i would suggest you to take help from a professional data recovery company.
Mar 22, 2013 | Transcend StoreJet 25M2 500GB Hard Drive...
Crashed external HDD Verbatim
Hard drives are easily damaged by dropping them.
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 15, 2012 | Computers & Internet
Hard drive makes clicking noise and won't come on. Same happens upon turning the drive off and on. Is there any way I can recover the files on the drive? Thank you.
When the hard drive makes a clicking noise, it has died (known as the click of death).
A user cannot recover data from these faulty hard drives, but there are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Feb 02, 2011 | IOGear (GHD335C250) 250 GB Hard Drive
My hardisk showed 2000-0146 error and it got replaced with new harddisk.. can i recover data from my old harddisk?
Try connecting the hard drive to an USB hard drive adapter and connect it to a computer's USB port. The computer should see it as an external storage device and you can open the various folders and files to backup your data.
If the computer cannot detect the hard drive as an external device then the hard drive is faulty.
If the hard drive makes a clicking noisy then it is definitely faulty and replacing the circuit board cannot fix this problem.
There are companies that can retrieve data from a faulty hard disk BUT it will cost you an arm and a leg for their services.
Jan 24, 2011 | Dell Latitude D630n Notebook
Samsung HDD does not get detected any more. I have very important data and want the data to be recovered at worst case. HDD is old one and makes strange sound when connected. Even if I connect it in...
Try to connect it as a master. Just connect this hdd only, so we can know if is detected in the bios. If yes then there's a possibility that you can recover your data. If you hear clicking noise/strange sounds then there's also a big chance that your hdd is broken. If it is detected in the bios, then remove it again and try using an external casing so you can put this hdd in it and connect it to your pc thru usb. I assume that your hdd is an ide and not sata since it's old as you say. Then to go to windows and see if your hdd in external casing is detected. Another option is that if it is detected in the bios, use a bootable cd with software apps for Hard disk tools like HDD Regenerator or HDAT2 to check and repair bad sectors on your hdd. Use this at your own risk and may destroy all data on your hard drive. If noe of this works, then you can assume that your HDD is not functioning anymore.
Nov 03, 2010 | Samsung Computers & Internet
Hard disk not detected - Need to retrieve data
If it is your system drive (C:)
You can remove it and try connect to another computer (internal or in an external caddy).
Usually you can get the information you need like this.
Jul 23, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
May 15, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Hi there, seem to have lost my external harddrive on my desk top, and it is making a beeping sound??
Hard drives don't beep. They make a lot of sounds, but no beeps. If the drive is actually making an unusual noise, it has probably gone bad. Clicking would be a bad disk. Any other noise would be a bad controller board. A good shop may be able to slave your drive to another computer to try and save your data. But don't count on it. By the time a drive makes a loud noise, it's usually gone and unrecoverable.
Before spending a lot of money to recover your data, try the external drive on another computer. Maybe the connection USB port has gone bad on the original computer.
Nov 12, 2009 | Maxtor Hard Drive
The hard drive fell over and now it wont stop making alarm noises and it wont work
I'm afraid the disk got damaged internally. If it was set to RAID 0 mode (speed), at least half, possibly all data is probably lost.
If it was set to RAID 1 (safe) mode, maybe the data can be recovered. It's not very likely, I'm afraid, because in this case the drive would make noises but would also work. I fear you had two 512 Gb disks configured as RAID 0. For RAID 1, it is sufficient to open the enclosure - it has three small screws on the side - and unscrew the four internal screws holding the drive caddy. Extract the caddy, unscrew both hard disks, and try connecting them, one at a time, to an external SATA to USB adaptor (Kraun makes a very handy USB to SATA-EIDE3.5-EIDE2.5 adaptor with external AC, but many exist).
In RAID 1, one of the disks might be detected and work (of course, both could have been damaged, but that would be real bad luck).
In RAID 0, sometimes it is possible to partially recover one of the disks (with half the data). It takes lots of luck, not all RAID 0 enclosures support this.
If you can't recover the disks easily (the RAID 1 trick is almost immediate), I'm afraid your only option is a data recovery service :-(
Nov 04, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Hard drive dont load up properly
your hard drive is dead mate. sorry. they die form time to time.
buy yourself a new hard drive and an external hard drive caddy (a 3.5" one) make sure the caddy is the right connection for your old hard drive. either sata or ide.
then put the new hard drive into your pc to take the place of your old one, and load windows onto it.
next get your old hard drive into the usb haddy drive caddy/enclosure, connect it all up and see if you can use the ghost function on norton anti-virus secruity to bring back your old data.
hope this helps.
kev
Oct 02, 2008 | Acer Aspire T310 PC Desktop
Computers & Internet Logo
David Payne
David Payne
