Question about Freecom (24358) 160 GB Network Hard Drive
Free space availabilities
I have 122 GB free memory on my FREECOM external hard drive. However, when I try to copy a movie of only 4.22 GB a message appears: The file is too large for the destination file system. Interestingly it does allow me to transfer movies of 699 MB without any problems. I have tried restarting the laptop; check the volume for errors and defragmenting, none of which worked.
Thank you.
  • Ivalinki Jan 16, 2008
    Thank you for the swift reply. Unfortunately, I am not familiar with formatting and the different types. Where can I find what format is my hard drive and how exactly can I change it? The hard drive is FREECOM Classic SL 250 GB.
    Many thanks.
  • Ivalinki Jan 17, 2008
    It is FAT32 and i will try to reformat it to NTFS as soon as possible. Thank you very much for you great help.
    President:
  • 317 Answers
Is it formatted as FAT32? If so, it doesn't support files larger than 4GB.
Backup the files you have on it, then reformat as NTFS.
Posted on Jan 16, 2008
  • Anonymous Jan 16, 2008
    Open "my computer"
    Find the device, right-click it and select properties. It should tell you there the file system.
    When you format, do the same thing, but instead of properties, select format. Make sure you format it as NTFS.
  • Anonymous Jan 17, 2008
    Glad I could help
6ya staff
SOURCE:
My samsung external hard drive can't copy large files
Well I would say make sure that the size of the file you're sending is lower than the available free space on your external hard disk.
And also, some ext. Hard disk has partitions, make sure your pasting in the right partition that has free space.
I hope this helps. Thanks for using FixYa!
Sep 11, 2012 | Computers & Internet
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
Data Missing from 250GB Freecom HardDrive.
May be that is hidden..Go to the control pannel look for folder options and then in the view tab check the box show all files and then click ok.
connect it again see if are able to see your files again. if not then there are data recovery tools available on the internet.
But i think the first method will solve your problem
Jul 28, 2010 | Freecom (24358) 160 GB Network Hard Drive
I have a Verbatim 250USB drive and have never had a problem with it until I attempted to copy some HD movie files to it from my computer's hard drive. I am attempting to copy .mkv movie files to the...
firs:
try to format your hard drive, then try again.
if you still cannot do it, do a low level format, using this tool:
http://hddguru.com/software/2006.04.12-HDD-Low-Level-Format-Tool/
if you still cannotdo it, it may be a harware problem. try to copy a big .mkv file like that from another pc, to be sure it isn't your pc's fault, if you can do it, then it's your pc, if you still cannot it's the disk.
in the firs case the troublesooting is quite difficoult but if you post your system configuration i may help.
in the second case if allso a low level format fails, then i don' think we can do something for youo... you should get assistance from the manufacturer....
hope this help,
Paolo.
May 19, 2010 | Verbatim SmartDisk Firelite Portable USB...
I have a lot of photos on the external Freecom hard drive. I've changed laptops, and have lost the CD, and anyway, can't remember the password! help!
This should not be to hard to recover.
Unless reformatted it is likely that only file indexing problem is the issue.
External hard drives are for copies.
Never allow a to ever be your only copy.
FREE FILE RECOVERY PROGRAM GOTO:
www.recuva.com
Just choose a drive,
Your Hard drive.
Then click the Scan button.
Hope this Tip helps you.
From someone who has lost a lot of Data
r/
David
Feb 19, 2010 | Freecom (24358) 160 GB Network Hard Drive
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
No space error
This is due to the file transfer limitations bound by the file format FAT32 (no files larger than 4GB and no folders that contain more than 1000 files). Try formatting the drive to NTFS.
Dec 30, 2008 | Western Digital My Book Essential 1TB...
Ps3
most likely your hard drive is full.
Go to Settings-System settings-System information. it should tell you free space on your hard drive from your total available space.
Your drive is probably filled with demos and saved data from previous games, maybe music or even dowloaded movies.
If still had the same issue after the restore there is a chance that your hard drive was swapped for a very small one. ckeck the system info first:
Free space : 12 GB/37 GB this is for a 40 gb
If that is the problem you need a different hard drive (SERIAL ata 5400 rpm ).. upgrading the hard is easy.. or even go with an external drive.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
Freecom (24358) 160 GB Network Hard Drive Logo
338 people viewed this question
Top Freecom Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Greg Ulan
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
