2006 Honda ANF125 Innova Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i derestrict my lifan s-ray 50cc 4-stroke scooter please? forgot to add its a honda based engine and its a 59 plate thanks
Anonymous
Level 2:
  • Expert 269 Answers
  • Posted on Dec 03, 2009
Anonymous
Expert
Level 2:
Answers
269
Questions
0
Helped
131238
Points
600
Unless you find a small "restricting washer" between the head and the exhaust pipe...Then usually there is no easy means. In the past these "washers" were put in place to reduce performance, the idea was as the riders skills improve the washer can be removed. It also was a way for parents to keep their children from zooming flat out everywhere.
BradleyTownsend
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 27, 2013
BradleyTownsend
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1892
Points
I have a lifan mirage 125cc 4 stroke does anyone know how to De restrict them
I have a 2013 Honda Metropolitan 50cc scooter. In a week of sub zero temps, I attempted to start. It ran for about 10 seconds. Unable to start it since. Assumed fuel line freeze.
Question edited heavily and to add maker.
Question moved from Cars and Trucks to model category.
This is a 4 stroke engine and gasoline doesn't freeze, only diesel goes syrupy. The most likely reason would have been condensation and damp causing the spark to short out. Another possibility might be old gasoline?
Engines only need three things to run
Fresh clean fuel.
A spark at the right time.
Compression
When was it last serviced, spark plug checked and gapped? Spray some WD40 on electrics.
https://www.google.com/search?q=2013+Metropolitan+50cc+scooter+no+start
1helpful
How to derestrict the CDI of a 50cc TGB Bullet RS. Model 2013 or 2014
derestrict the CDI of a 50cc TGB Bullet Anon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ScooterCommunity
How to replace the cdi box on your scooter with performance cdi box
How to derestrict 50cc Scooter TuningMatters com
1helpful
Oil in engine scooter
to start with is it a 4 stroke or 2 stroke. If it is a 2 stroke the oil goes in with the petrol. If a 4 stroke look for a removable plug in the crankcase
Lifan 50cc scooter not starting. I replaced choke solenoid and cleaned the carb. Am getting spark and putting sight vacuum on on hose leading to gas tank valve does produce gas flow in hose attached to...
It requires three main things to start the scooter:--- 1)Gas. 2) Spark. 3) Cylinder compression.---------- Any of the one is not functioning right so scooter is not starting.------------ Its possible that gas is not flowing till the carb and that is causing the problem.Either gas valve is clogged or faulty.Or gas line is clogged or carb itself is dirty and gunked up inside and needs to be cleaned.--------- Click this link below and follow the troubleshooting :--- http://whatisbyme.blogspot.com/2011/08/lifan-50cc-scooter-not-starting.html ----------- This will help.Thanks.Helpmech.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
