Question about LG WM1814CW Front Load Washer
Lg wm1812cw front load washer
I have noticed laundry soap leaking out the bottom of the dispenser tray.  When I took the tray out there was laundry soap or fabric softener build up below the tray.  It was so built up that it came to the bottom of the dispenser tray.  In some areas it was 2" deep.  I cleaned this out and did a load of laundry.  I took the tray out to see if there was any residue.  When I ran my finger across it there was laundry soap still in the bottom, below the dispensing tray.  I did not use fabric softener in that load and I only use the fabric softner in the summer when I hang clothes on the clothes line.
What can I do to have all of the soap rinsed into the machine?
Angela Larrabee mlarrabe@netzero.com
  • Angie62 Feb 05, 2008
    This makes sense to me.  We have a whole house filter, that gets clogged and the water pressure can be slow when the filter needs to be changed.
    Thank you
  • Anonymous Mar 21, 2014
    Took soap dispenser out to clean and cannot manage to get it back in place.
  • 3 Answers
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Posted on Feb 10, 2008
    Problem Solver:
  • 9 Answers
Is your water fill cycle slow? If there is not enough water supply pressure due to blockage, a trickle may not be enough to get all the soap into the tub and you'll be left with a wet clump of soap. If you've got a brisk supply of water, then it isn't flowing through the soap dispenser properly. Good Luck!
Posted on Feb 05, 2008
My lg washer appears to be leaking from the soap tray area, what needs to be replaced and how?
The hose from the soap drawer to the tub may be split. These hose have flexible ridges and its common for them to split inside one of the ridges.
Sep 17, 2017 | LG WM-2277HW Front Load Washer
Help ! We have an L G front Load washer model # WM2016CW that leaks soap out the front bottom of the dispenser. It is 2 years old and I have followed all the manufacturers instructions on using HE soaps...
You can remove the dispenser and place it in the dishwasher for easy cleaning.
I have included some notes on your washer and I have a service manual for you HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 07, 2011 | LG WM-2277HW Front Load Washer
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
Fabric softener does not drain out but remains in the tray. Tray fills with water and stays there. I have cleaned drain hole at tha bottom with pipe cleaners and it is clear! This is on a front loas...
I'm having the same problem with the fabric softener dispenser not emptying and filling with water. I, too, have cleaned everything out and there are no clogs. What's the solution?
Dec 29, 2009 | Samsung WF203ANW Front Load Washer
LG WM1814CW Front Load Washer Logo
2,558 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
