Question about Miele CVA4070 Coffee Maker
Stuck while cleaning
Did the cleaning process per manual on on screen directions.  Stop at 1 minute.  Waited 15 minutes.  Turned off power for 30 seconds and when I turn it on the screen still says "cleaning"  All buttons do not work.  Suggestions please.
  • TSsmith Jan 17, 2008
    So I paid you $9.00 for expert advice which was to give me the phone number that I already have on my owners manual?  I had called and they were closed so I thought I might try your expert advice.
    Thanks
    Scholar:
  • 128 Answers
If your Miele appliance requires service, please contact our Technical Services Department at:
Phone:
(800) 999-1360 (appliances)
Posted on Jan 16, 2008
  • Omair Chughtai
    Omair Chughtai Jan 27, 2008
    Well if you had their phone number you should have waited till they re-opened and called them instead of paying 9 bucks.
Any way to stop the intermittent screen flashing for my Sony kv-32S42?
Is the unit plugged directly into a wall AC plug?
Are you using a power strip?
Have you changed any settings either on the unit itself or on the original remote or are you using a different remote?
Are there any other high voltage units connected to the same wiring?
Aug 20, 2018 | The Watches
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
I bought the tb100 30K-55K propane heater I hooked it up to a fully filled 20 pound (5 Gal) propane tank and it ran fine for about 45 minutes then the burner shut off. I restarted the heater per the...
Make sure that the thermocouple is well into the flame. Check to make sure the other end is secure into the gas valve. Check for any poor connection both gas and electric. If the LP cylinder is icing up, it is a vaporizing problem and the heater is sucking the available gas out of the cylinder faster than it can vaporize. You will need a larger cylinder.
Nov 25, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Oven door locked and fan going frigidaire professional range
Did you solve your problem? I just got stuck in the same situation! How did you stop it?
Jul 09, 2009 | Electrolux Frigidaire Professional Series...
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
I have a sharp dv-rw260h. I put a DVD in to check what was on it and the machine won't stop 'reading'it. Cannot get machine to do any other function whilst it is 'reading and cannot find a manual dvd...
Turned machine off at the mains for about 15 minutes. When I turned it back on, it started 'reading' again but then a message came on screen saying that it was checking the disc....it said that the procedure would take about 15 minutes but stuck on 'five minutes left'. Tried the eject button again after about 2 hours and the drawer opened. Checking message still showed so I turned the machine off and on again and everything was fine.
Jul 23, 2008 | Televison & Video
Storing music in BOSE 38 system
The Bose uMusic system is a very powerful music management tool. The uMusic storage process involves pulling information from your CD (approximately 3-5 minutes per CD) then storing this information into a buffer area for processing. The buffer area will hold approximately 10 CDs worth of data. After the buffer is full, it must stop taking new data and process the data already in the buffer. The processing time is about 30 minutes per CD.
This means 5 - 6 hous of processing per 10 CDs. So be patient. This is not unusual. Other "media servers" such at Escient and Audio Request take 24 - 48 hours to process a full buffer. There is a lot of data processing going on during this time period and the result is amazing music management once completed.
I recommend clients load 10 CDs in the morning and let it process till after lunch. Then another 10 CDs and let it process until after dinner. Then another 10 CDs and let it process overnight. This routine completes 30 CDs per day.
If you have 100 to 400 CDs an automated services is available from HouseSys.com. This is the only automated service available for this system.
Jan 20, 2008 | Bose Lifestyle 38 System
Miele CVA4070 Coffee Maker Logo
382 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
