Question about Sharp AR-5316 Advanced Digital Imager Copier
Tractor feet worn
I have two ar-150n sharp machines in home use. How easy is it to obtain and change the tractor feet that pick up the paper? I am wasting too much paper because the feet are worn. i have cleaned them with alcohol but it is not a longterm solution.
  • Larry6781 Feb 09, 2008
    SINCE REQUESTING HELP, I DISCOVERED THAT THE HOUSEHOLD CLEANER "CINCH" HAS THE RIGHT CHEMICALS TO CONDITION THE TRACTOR FEET. I USED IT AS DIRECTED AND NOW BOTH MACHINES ARE WORKING LIKE NEW. I CAN'T WAIT FOR THE NEXT COPY MACHINE SNAFU. A NOTE TO ANDY - CRICKET BATS ARE ACTUALLY LESS COMMON THAN HEN'S TEETH HERE IN WESTERN NEW YORK STATE. THANKS FOR THE IDEA.
  • 61 Answers
Hello, depends where you are in the world, if you are in the uk i could send you some. Alternatively what i have done in the past is cut up cricket bat handle rubber to size and glued them over the existing tyre, regards
Andy
Posted on Jan 17, 2008
Sharp AR-5316 not picking paper from the cassette
Remove the paper cassette. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 04, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-150N displaying F2 Error code.
Hello sir; I can't find this error code in my manu please check your code again.
Aug 12, 2009 | Sharp Office Equipment & Supplies
My copier AR-M208 won't pick up paper from tray 2 It starts too then nope it says its jamed but not really, we open side door and tray close both then it will copy one or two pages the stop again
It may be that either the feed rollers in that drawer are dirty or worn out and need replacement. You might also want to ensure that there is no dogeared paper in that drawer. Meaning that the edges of the stack are all nice and even, no corners bent over.
Jun 29, 2009 | Sharp AR-M208N Copier
Adf misfeed ar-m237
Try cleaning the pick rollers with alcohol or clean cloth dampened with water.
Feb 10, 2009 | Sharp AR-M237 Copier
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Jan 28, 2009 | Sharp AR-M350U Copier
Sharp AR-150N error code E7
The E7-02 is a laser unit problem. I do not know the part number for the laser sync motor but you and just replace that instead of the whole laser unit ( alot cheaper). If I can find that part number I will get it to you. Remember , if you do replace the motor, replace in as clean and still air area as possible. If something gets into the area of the laser/motor, it could scratch one of the lens on the laser head and it would be trashed.
Jan 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M355 copier with AR-EF3 adf
With what you described it sound like the paper out sensor is not working properly, might be bad or broke. Hope that Helps... Lbcoaster
Jun 27, 2008 | Sharp Office Equipment & Supplies
AR-150N series copy machine. Making loud clicking sound and has CH on display. Need manual for this machine also.
CH means door is open, flashing CH means problem with toner cartridge You may need to replace the toner cartridge, the op manual can be downloaded at: http://www.sharpusa.com/files/cop_man_AR-151.pdf
The 151 is the same to the 150
Hope this helps you...
Jun 06, 2008 | Sharp Office Equipment & Supplies
Ar-5320
Usually, it flashes "P" in the display for Paper.
Either the paper tray is empty or the feed rollers tried to pull the paper out of the tray and it failed.
If there is paper in the tray, then the feed rollers might be dirty or worn.
Try cleaning the roller with something like Fantastic, or a multi purpose cleaner.
And see if that helps. IF the rollers are worn, then they would need to be replaced in order to get your machine back to normal.
Hope this helps.
Good luck.
Mac =)
(please remember to rate this answer if I have helped you. THANKS =)
Mar 28, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
