Question about Emerson MW8102SS 1100 Watts Microwave Oven
Emerson 1000 Watt Microwave
Every once in a while when using microwave, it makes a loud popping sound. It sounds the same way when it arcs. Can this be repaired by me? If so where can I get part.
    Novelist:
  • 139 Answers
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Posted on Jan 17, 2008
6ya staff
SOURCE:
My Whirlpool microwave over-the-range oven makes a loud roaring sound when it turns on and won't heat.
Sounds like it could be a bad magnetron. The roaring could be a shorted mag or possibly a mag arcing in the wave guide If it is arcing in the wave guide, better to replace the unit.
Nov 01, 2017 | Microwave Ovens
Microwave popping sounds and flashing lights
The magnetron may be arcing, get warm soapy water and remove all food particals from inside of microwave oven until spotless, and check the hood for bare metal.
Mar 18, 2012 | Hamilton Beach Microwave Ovens
Microwave made loud pop when started
It does sound like it may be arcing causing snapping sounds, if bare metal is exposed it will arc and eventually cause the maghetron to fail. It is possible the magnetron is breaking down, but for safety issues it should be checked.
Mar 04, 2012 | Sharp R-1871 Convection Microwave Oven
Microwave making loud buzzing sound when operated, sounds like something is about to pop.
could be several possible components at fault. how old is it ? does the unit heat ? if so, could be a hi voltage diode, or a hi voltage tranformer. (older frigidaire m'w's had trans. that would crackle and "arc" when bad) it is not the mag though, it wouldn't heat if so.
Sep 25, 2009 | Microwave Ovens
My goldstar above the stove microwave popped and now won't heat. Everything else on the unit still works. Is this a problem that can be repaired? Thanks.
Did it make a loud pop like a firecracker?
Sounds like the High Voltage Diode shorted out and it probably is making a low or loud growling noise now..... ???
Sep 11, 2009 | Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave made loud popping sound and now does not heat.
Hey,
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
GE xl1800 spacesaver microwave
It sounds like you could have one or two problems. Using the oven with metal in it could cause the magnatron to go bad at its tip causing it to arc and making a popping sound. It could be that there is bare metal exposed somewhere causing the popping sound. Take it in for service!!
Feb 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
217 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
