Question about LG RH266 Recorder
Record at once on dvd?
I would like to know if its possible to record a tv programm on the disc at once? Or do i have to record on HDD everytime and then dubb it on dvd?
Kind thanks,
No direct record from TV to DVD on this model, yes it is very annoying...
Posted on Feb 09, 2008
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
WHAT DVD DISC DO I NEED TO RECORD ON
On the front of the unit it will say either DVD-R, DVD-RW,
or DVD+R , DVD+RW.
The R means Record once The RW means record erase record again.
RW is more expensive. It is important to get the + or - correct.
Hope this helps you. Enjoy, it is FUN !!!!
Jan 28, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
Cannot record without watching the programme
This unit does not have twin tuner,you would have to watch another channel on the tv.
Dec 03, 2009 | Panasonic Televison & Video
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
TOSHIBA RDXV45KB
This is a disc read problem the discs recommended in the manual seem to be the only discs that will work on this machine.
I was getting the same error code everytime but the disc that i know does work is a Verbatim 16X DVD-R.
These discs work in all situations on my machine , dubbing and direct from TV.
Mar 22, 2008 | Televison & Video
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Probs with set-up of new RD-XV47KB to new Toshiba ZF355 television
i can only record 1 programme on the hdd if i try to record another programme it starts back at the beginingt
Jan 10, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Pioneer DVR 640 H
You may have CDs stored in the Jukebox taking up space- if so delete them.
You may have images stored in the photoviewer - again, delete...
Have you done any disc backups, and forgot to delete the backup file? Goto bottom of copy menu for disc backup, then in the disc backup menu, choose delete backup file.
Jan 04, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
LG RH266 Recorder Logo
47 people viewed this question
Computer Repairing
Computer Repairing
