Question about Konaki MP4-NS MP3 Player
Mp4 ear phones
Hi.
When I [put my earphones into my mp4 u have 2 fiddle alote to get them in right so I can here the music coming out of both of the earphones.
How can I fix it???
  • bjvw Jan 16, 2008
    what do you mean by solder?
  • 4,102 Answers
Hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Posted on Jan 16, 2008
  • paul proctor Jan 16, 2008
    if you have replaced the ear phones and ruled out that as being the problem then you need to remove the case of the mp4 player and do you know the socket the earphones plug into well this is held onto the circuit board by to solder points but i wouldnt have thought this would be the problem.
    I would replace the earphones as this is the most likely problem
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
I plugged my earphones into my ipod and laptop to play music, and the music comes out of my left earphone, but not the right
This could the way the music is been recorded if it is strero or mono, also do confirm the earphone if one side of the earphone is faulty or not, if bad replace with the exact type and if not the media itself is faulty, you can take it the an electronics repair shop for them to diagonised the appliances... Hope this will help in solving.......
May 06, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
I have enjoyed my Bose headphones for a couple of years now and tonight I plugged them into my iPad to watch a movie and the sound from the right headphone diminished quite a bit compared to the left. I...
Could be possibly dirt in Ipad headphone jack (common prob) - put a drop of isopropyl alcohol in Ipad jack - just a drop. You might also check headphones in a computer jack to verify if it is possibly the headphones.
Apr 03, 2011 | Bose in-ear headphones - Black with...
Hi sir, this is ravi, my YP-S2 mp3 player ear phones got a problem ,only right side ear phone is working.sir pls, help me that there is any dealers for this type mp3 player earphones in hyderabad / in...
This earphone ( ear buds) is common type. You can find it, in some cellular phone /mp3 accessories store/shop in your town ( although they are not original part) .
Dec 06, 2010 | Samsung Cameras
Skull candy ink'd right ear phone muted
you could have blown the right earphone but its more likely that you have a damaged wire or connection somewhere. move the wire around and see if that fixes it.
May 06, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Left earphone just stopped working -
I just solved my problem. My left earphone wasn't working or would work some of the time with it cutting in and out depending on my head position or if I moved quickly. What I did follows:
1. Took ear pad off
2. Took black liner off of the inside of earphones. Glued on 2 spots.
3. Below the silver band of material is a clear plastic lining that covers the speaker.
4. I pressed that clear liner to see if it helped make the left earphone work and it did.
5. I had to fiddle with it to get it perfect but it worked for me.
I'm sure this would void any warranty and work on your own headphones at your own risk.
Aug 26, 2009 | Bose QuietComfort 2 Consumer Headphones
I need Help!! Plz Help Me!!!
The phones are probably not reaching the bottom of the connection where the MP3 is told to stop sending sound to the speaker.
Test with other phones.
If the problem persists, a firmware update would be a good idea.
Cheers
Jun 20, 2009 | Laser MP4-V970 MP3 Player
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Earphone socket in mp4 player not working properly
Hi alot of people have had this problem but as you didnt buy it new then you cant send it back to them as they would have repaired this for free if it was you who brought it.
It points to one of two problems as you say some of the keys are not working also then this could be a sign that the mp4 has got damp or wet at some stage causing the terminals to corrode this could be solved by removing the case and cleaning the contacts behind the buttons.
Taking it apart isnt easy and you could easily destroy it completely as for the ear phones not working i know you said it works fine in a different device but it is still worth buying a cheap set of ear phones just to bw 100% sure as they only cost pennys nowadays.
If you still have the problem after trying this then i would say that its either the damp or wet problem again with coroded connections shorting on the ear phone jack or it could be that it needs the two contacts resoldering but this isnt a job for someone who has never done this repair before as you can ruin it all together ok.
Sorry their is no easy fix but hopefully you get the sort of idea what the problem could be anyway let me know if you need further assistance ok
Mar 19, 2008 | Apple iPod nano
Technika MP3 player model MP407 2 GB
i bought a mp4 player 2 months ago through net when i brought theplayer it was working fine but now it has totally changed its keys arenot working properly and earphone socket also not working properly .When I [put my earphonesinto my mp4 u have 2 fiddle alote to get them in right so I can here...and also the earphones are working fine with other mp3 and mp4 playerso i don't think there is any problem in earphones
Mar 19, 2008 | Audio Players & Recorders
Konaki MP4-NS MP3 Player Logo
78 people viewed this question
Top Konaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Konaki Audio Player and Recorder Expert? Answer questions, earn points and help others
