Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Jenn-Air self cleaning wall ovens model W2451
We can see a bug in the clock on our Jenn-Air oven. How can we get to it to remove it? Thanks. My e-mail is canderson107@tampabay.rr.com
Charie
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
Posted on May 08, 2008
My jenn air wall oven will not begin the self cleaning process. I've followed the directions in the owner manual. The process stops after I close the oven door. The door is not locking
good don't use it,more ovens get damaged when the self clean feature is used,the oven gets up to 1000 degrees and the heat can damage the electronics in the oven,after seeing all the ovens that get damaged i tell customers not to use it use easy off instead,i will never self clean an oven again,one more thing if you do get it to work don't use it before the holidays use it after just in case something does happen you might not be able to get any parts in time to repair it till after the holidays,usually it takes out the clock assy. and this isn't just a clock that's a computer board built in with the clock and this runs the oven,a lady self cleaned her oven the day before thanksgiving and her oven is old,they don't make the clock assy. anymore and she couldn't get a new oven in time either so this could be a blessing for you.if the oven works leave it alone and clean it after the holidays,if you want to fix it write back in but you need to send the model number off of the oven.good luck.
Dec 17, 2017 | Ovens
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Aug 11, 2011 | Jenn-Air Ovens
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a problem with my jenn-air oven model w256w. On the touch appear F8 alarm. What can I do?
Hello- The code described- F8 indicates a failure in the clock, or control that operates oven. There is no simple 'fix' to this problem. "Self- clean" is the usual cause of board failure. Find a good tech to check it out on site Get an estimate before repair, and remember- Avoid "self-destruct" feature in the future. --Please reply if this info helps- have more if needed.  Thanks- Ed
Mar 18, 2010 | Jenn-Air Ovens
The heating element failed on my W2451 wall oven. Is it something I can replace myself?
skill level ( easy ) 15 min . open door / remove racks / two screws . pull out slowly . two wires remove and reinstall to new element and reinstall . done . don't you feel better now .. mm
Nov 22, 2009 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
301 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
