Restart notification i wonder how to remove the restart notification when im have applied new dns ip in my network setting....
watch this video on what im talking about...
http://www.youtube.com/watch?v=gN329sLNxjE
Try different using a different DNS address. OpenDNS provides free, fast servers that are used by millions. Here's how to do it with and without a router in your set up:
WITHOUT A ROUTER:
Mac OS X
Go to System Preferences.
Click on Network.
Select the first connection in your list and click Advanced.
Select the DNS tab and add 208.67.222.222 and 208.67.220.220 to the list of DNS servers.
Click OK
Windows 7
Click the Start Orb, then select Control Panel.
Click on Network and Sharing Center.
Click on your primary connection or Local Area Connection under Active Networks.
Click the Properties button.
Windows 7 may prompt you for permission to make network setting changes.
Highlight 'Internet Protocol Version 4' and click Properties.
Click the radio button 'Use the following DNS server addresses:' and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
Click OK button, then the Close button, then Close again. Finally, close the Network and Sharing Center window.
At this point, we highly suggest that you flush your DNS resolver cache and web browser caches to ensure that your new configuration settings take effect.
Windows XP
Select Control Panel from the Start menu.
Click Network Connections from the Control Panel choices.
Choose your connection from the Network Connections window.
If you have more than one, choose your default/current connection.
Click Properties button.
Select Internet Protocol (TCP/IP) and click Properties.
Click the radio button Use the following DNS server addresses and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
Click OK
Windows Vista
Click on View network status and tasks.
Click on View status.
Vista may ask for your permission to make changes. If so, click the Continue button.
Select Internet Protocol Version 4 (TCP/IPv4), then click the Properties button.
Click the radio button "Use the following DNS server addresses:" and type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in the Preferred DNS server and Alternate DNS server fields.
Click the OK button, then the Close button, and the Close button again. Close the Network and Sharing Center window.
WITH A ROUTER:
Generic Router
Open the preferences for your router. Often, the preferences are set in your web browser, via a URL with numbers (example: http://192.168.0.1). You may need a password. If you're like us, and you set the router password long ago and cannot remember it now, you can often reset the password to the manufacturer default by pressing a button on the router itself.
Or preferences may be set via specific application for your router, which you installed on your computer when you added the router.
Find the DNS server settings.
Scan for the letters DNS next to a field which allows two or three sets of numbers, each broken into four groups of one to three numbers.
Put in the OpenDNS server addresses, 208.67.222.222 and 208.67.220.220, as your DNS server settings and save/apply.
Linksys Router
Visit the router's IP address in a new browser window. http://192.168.1.1 is the default Linksys router IP address.
Enter the Network password.
The "Enter Network Password" window will appear. Skip user name and type the router's password (admin is the default password, if you haven't changed it) and click the OK button.
Type in OpenDNS addresses, 208.67.222.222, 208.67.220.220, in Static DNS 1 and Static DNS 2 fields.
Type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS and Secondary DNS fields.
Click Apply button.
Wait for the settings to be updated.
D-Link Router
Visit the router's IP address (http://192.168.0.1) in a new browser window.
If you are attempting to configure a D-Link router, take note of your computer's Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. Most D-Link devices use the 192.168.0.X range.
Enter the router password.
Note: if you have not changed the original settings, the default username is admin and the password is blank (nothing).
Click on the Manual Internet Connection Setup button at the bottom.
Enter the OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS Server and Secondary DNS Server fields.
Change your DNS settings manually on the PS3 via XMB > Network Settings > Internet Connection Settings > Manual. Just allow the default entries until you get to dns, select manual and change it to 8.8.8.8 for the main dns and 8.8.4.4 for the secondary dns.
Go to your router settings, select dmz and add your ps3 IP address to the list and select apply. You can see your ps3 IP address in XMB > Network Settings > Settings and Connection Status list.
Change the password for your PSN account. The easiest way to do so it to log in via their website on a computer.
Restart your ps3, sign in using your new password and you should be good to go :)
Changing the DNS settings to 8.8.8.8. and 8.8.4.4. on BOTH the
modem/router AND on each pc on my network in the Tcp/Ip lan or wan
settings (in detail bellow) solved this ERROR 105 issue for me,
To change DNS settings (in Win 7) go to Control Panel / Network and
Internet / Network and Sharing Center (may be listed as "View Network
Status and Tasks" in control panel)
Next click on your connection (Local area network or Wireless area network)
click on Properties
select Internet Protocol Version 4 (TCP/IP v4)
click on Properties (yes, again, but this is a different window)
click Advanced and select the DNS tab
Select any DNS addresses here and Click remove. Make sure there are non left
Click OK. you should now be back at the "Internet Protocol Version 4 (TCP/IP v4)" window
without altering the IP settings at the top, select "Use The Following DNS Server Addresses"
in the first area write 8 . 8 . 8 . 8 . in the second write 8 . 8 . 4 . 4 .
next either:
1 select "Validate Settings Upon Exit" and press ok or 2 press ok and then restart the network connection for changes to take effect (In other words find your connection in "Network and Sharing Center" and click the "Connect or Disconnect" option above it to disconnect, then select connect to a network in the same window, select your network and click connect")
1 - Assign a Static IP address in the Xbox:
- Go To Network Settings - Configure Network
- Change IP settings to Manual
- IP Address: 192.168.2.45 Subnet Mask: 255.255.255.0 Gateway: 192.168.2.1
- DNS settings to Manual
- Primary DNS: 192.168.2.1 Secondary DNS: 4.2.2.2
2 - with any of the Wired Computers
- open IE - type - 192.168.2.1 - u'll get the Router Interface
- left hand side in the list of options
- click Firewall - leave password blank - disable and apply changes
- click Virtual Servers;
- under enable place a checkmark
- description : Xbox, Inbound Pot : 80(if there are two boxes here duplicate in both the boxes), Type: TCP, Private IP: 45, Private Port: 80
- So Similarly fill up the table for these following Ports
TCP: 80, UDP: 88 Both(TCP&UDP): 53, 3074
Additional Note:
If u've a DSL connection, call ur ISP and make sure ur modem is bridged and the NAT is disabled
1) Get connected to belkin's wireless network or wired network 2) Once you get connected, it may not be able to go online on XBox Live 3) Go to any computer that is going online with the router 4) Type in 192.168.2.1 in the address bar of your Internet explorer 5) This will open up router interface(here we have to do some settings) 6) In the left hand side column, click on FIREWALL. 7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes. 8) Under FIREWALL(in the left hand side column), click on DMZ 9) Make a "check" on enable and under Private IP: 192.168.2.25. Click on Apply Changes. 10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration IP: 192.168.2.25 Subnet: 255.255.255.0 Router: 192.168.2.1 11) Now select manual configuration for DNS settings. Primary DNS: 4.2.2.2 Secondary DNS: 4.2.2.1 12) Restart both Belkin and Xbox 13) It should connect to XBox Live now...
First connect your router to computer with ethernet lan cable. Then you can access it with following link. http://192.168.1.1 or http://192.168.0.1
If you are not able to access it with above ip then check your computers ip and gateway ip is your router ip access router with it. Then it ask for user and password. Type user as "admin" and password as "admin" orblank or "password" Then you can see configuration page of router. Then configure DNS settings in wan settings as dns ip get automatic from internet service provider. Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
This sounds like a common DNS issue. You need to make sure that this server has a local DNS server like 192.168.1.1 and not an external one like 4.2.2.2.
Your server is trying to find the domain controller and with the external DNS it cannot. This is why when you remove the cable it loads correctly. it assumes that it is disconnected from the local network and it continues without the domain controller. otherwise it waits for the external dns to time out.
please right click on my network places go to properties u will find a network connection i.e, local area connection right click on it go to properties there u can see two check boxes remove the lower one i.e,Notify me when this connection has limited or no connectivity and i f any problem in ip address go to Internet Protocol TCP/IP option select it and go to properties then u can change ip address, subnet mask,gateway and DNS server addresses if u know these parameters properly change and say ok apply ok it will restart the machine thats it
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can
connect all your devices by ethernet cable to the internet then it's
set. If you are using a wireless connection and if it asks for the WEP or
WPA key, make sure that you are entering the correct encryption key.
You may want to call your router manufacturer to know the correct key
for the wireless connection. FYI, it will say that the wireless network
is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I
suggest you to call your Internet Service Provider to check for the
Internet connection and obtain these (static IP address, subnet mask,
default gateway, primary DNS server and secondary DNS server). If your
Internet is okay, enter the IP settings manually on the console (System
> Network Settings > Edit Settings > IP settings).
