Question about Panasonic KX-T7730 Corded Phone
Two line phones - voice carry over
This is a small office with several different types of phone. They are 2-line phones. When I am on line 1, and a call comes into line 2 - I can hear that conversation as well as my own. This happens on all the phones.
How can I solve this problem.
    Scholar:
  • 146 Answers
Could be dampness in a connection box, or faulty switchboard (if there is one ) and it could also be an external line fault, your first step should be to get the phone company to test the lines or carry out a self test if your phone company has this facility code.
Hope this helps you a bit !
if all your office phones are internal and there are no damp locations, I would opt for moisture ingress in some of the external cables causing a line fault, could also be line induction, but phone company can check.
Posted on Jan 16, 2008
Have a 3010 SD and only line 1 rings, there are 4 lines.
The telephone has several capacities mentioned as four lines where each would have been networked a separate devices to attain voice communcations. The telephone service provider usually would request to either install at the location several beyound online jack to make possible several entities communcations. Also, the phone with several line becomes useful in situations where several office spaces require communcations sharing from the same telephone. Considering the number of lines that the telephone provider made avilable at the location, the telephone feature buttons can be used to select several lines of choice only that all four becomes tasked when four telephone connection jacks were established.
Feb 15, 2011 | Toshiba DKT 3010 Corded Phone
HOW DO I GET VOICE MAIL OFF MY COMDIAL 120 PHONES
Methinks the welcome message is stored in you telephone set. Try another set, or enter a new welcome messsage. Could it be that the telephone line carries two different lines. Check with you telephone company. Older service may have not been deactivated.
Just a few (possibly farfetched) leads for you to investigate.
Sep 04, 2009 | Comdial Avaya Partner ACS with Voice Mail...
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
AT&T 974 model small business system
How do I change the number of rings on the phone before it goes into voice mail? If I am not beside the phone, after 2 rings it will go into voice mail and I am missing calls. The model is AT&T 974.
Jan 15, 2009 | AT&T ATT-974 Corded Phone
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
Going to voicemail
The phone you have can go on several different Norstar phone systems and you can have several different types of voice mail. Your voice mail (and possibly the phone system) needs to have programming changes, not the telephone. Your first step is to determine which Nortel phone system you have and also what model voice mail. You will need manuals for the phone system and voice mail. Hopefully you already have a programming or administration manual for the voice mail. Someone should have gotten this information when the system was first installed but that could have been many years ago.
What happens when you are waiting for that time? Do you hear absolutely nothing? Instead of being sent directly to your voice mail box, it may be sending callers to a voice mail branch where you would normally have a recording "press 1 for this, 2 for that" If there is no recording the system will wait for a response that the caller has no idea of and usually replay the message 3 times before defaulting to your mailbox (in this case a blank message). That is my best guess with the information I have from you so far.
Nov 01, 2007 | NorStar T7316E Corded Phone
Toshiba dkt 2010-sd
Your first step is to find out which phone system you have. Your phone can connect to several different Toshiba phone systems and knowing the part number of the phone does not narrow it down any.
Also, if you are looking to change voice mail features like mailboxes, recordings, etc.. you may also need to know which model voice mail you have and find a completely separate manual for that.
Oct 10, 2007 | Toshiba DKT3010SD Corded Phone
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
