Question about Dryers
Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Hi, my Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button, already checked the breaker and there's no problem with it. I looked at the vent and was all filled with lint, any ideas what's going on with it?
  • Anonymous Apr 06, 2009
    My 2 year old MDE308DAYW dryer recently stopped running with burning smell in the cloth chamber. Found opened thermal fuse and replaced the fuse, hi-limit thermostat and the coil. Cleaned lots of lint from the vent. Dryer runs but imeediately emits the same smell in the cloth chamber, which is also very hot. But the dryer runs fine with heating off. My suspesion is over heating problem. what could be causing the dryer to overheat?
    Scholar:
  • 196 Answers
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Posted on Jan 18, 2008
Dryer just stopped wont turn
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Oct 07, 2012 | Maytag MDE308DAYW Electric Dryer
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
Maytag drier MGD308DAWW flame comes on for a few seconds then shuts off.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. There is a thermal fuse(part#33 in below schematic) inside the dryer near the blower assembly, check and replace.
2. Check for the amp reading at 240 V power inlet, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Also, make sure that the connections to the door switch are not loose & Motor wiring is not shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Jan 06, 2011 | Maytag MDE308DAYW Electric Dryer
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
Maytag dryer model MDE308DAYW will not start. Why?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Maytag MDE308DAYW Electric Dryer
Maytag dryer got wet in bassment. won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 07, 2010 | Maytag MDE308DAYW Electric Dryer
Motor works drum won't turn
heatman101
Jun 17, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
Dryers Logo
501 people viewed this question
Top Dryers Experts
