Question about Palm Tungsten E2 Handheld
Wrong command when I touch the screen
I have been using my Palm Tungsten E for around 4 years without problems. But since a couple of days, when I touch the screen I cannot go where I want. It brings me elsewhere. Could it be that I need a new battery? Is it that it is no good after 4 years? I hope not.
Many thanks,
Michet
  • cairn1 Jan 22, 2008
    Same problem & has gotten worse over last 2 weeks. Per Palm Manual have repeatedly re-calibrated touchscreen & checked for static electricity. Have used Palm for years, but E2 has given me more problems than any other model. Also, many errors now for 1st time when writing graffiti
    Problem Solver:
  • 14 Answers
Your battery is perfect no need of changing it.quite often touch screen gradually looses fades out,so u use it till it completely fades out and then get ur display changed.
Posted on Jan 31, 2008
6ya staff
SOURCE:
Unresponsive touch screen on Palm Tungsten E, buttons work
Often the problem on these is contamination that gets under the edge of the escutcheon which effectively presses the screen out of the usable area preventing entry in the normal area.
Using special screw driver (very small TORX) remove the covers and clean the screen edges. Note one has to gently pry the cover off when ALL screws are out.
A "sometimes works" method is to run a piece of paper or thin cardstock around UNDERNEATH the rim of the escutcheon to clean the contamination.
Note, you MAY need to "recalibrate" the screen after these procedures.
Jul 27, 2010 | Palm Tungsten E2 Handheld
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Hello my Palm TX will only show the Media and Install applications on my desktop, even though the hot sync says that it transferred successfully. I have all of the applications checked to be transferred...
your palm may just need a new lcd assembly.
it's not all that unusual the they wear out after some time. have you replace the battery lately??
if not I would start there and if you don;t get better operation look at replacing the lcd as for y it's not transferring apps i would think that could be software related and may a product of you software on your computer.
May 23, 2009 | Palm Tungsten E Handheld
The light on my palm pilot (Z22) screen is dimming.
There enlies your problem. Tungsten longevity. The display is a bulb that is dying. No adjustment. Tungsten won't touch it. It is a SEALED unit. Time to upgrade to an E2. I know alot about them too, including how to make it go internet. If you get an E2 ALL your info will cross over. If you have any questions, please create a new request, make it a premium, request it be for Just_Bobz and I can walk your through most anything you want to know. Please post this as fixya. Be talking to you soon. TY
Jan 24, 2009 | Palm Z22 Handheld
Palm Tungsten E/E2 digitizer - fragile?
Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
Dec 30, 2008 | Palm Tungsten E2 Handheld
Palm tungsten E2 touch screen unresponsive
I noticed this problem with mine and solved it by loosening the 4(four) T5 screws in the back. The problem is caused by a swollen battery. When the PDA is left charging for extensive periods of time, as mine was(several months of inactivity and never thought to unplug it), the battery will swell. It's still a good battery and holds a charge, but the increased girth presses on the internal boards of the PDA causing the screen to register a continuous "touch" and therefore seems locked. It's actually waiting for the phantom touch to release so it can act. Unscrewing the fasteners allows the body to expand, thereby releasing the pressure on the screen and letting the phantom touch go away. I'm going to see how well my e2 does without the screws in it at all for a few days. The front and back panels have "clips" molded into them which hold to the side frames, keeping it closed. But the fasteners are there to ensure the PDA doesn't fall apart all together. So, wish me luck. I'll report back in a few days and update this.
Oct 25, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 PDA battery
E2 has a great battery might not be it. Its not easyly replaceable like in some other models.
the battery can be replaced by a professional or by yourself.
The pda should work on charger? does it work while pluged in?
If it doesnt work while its pluged in theres something more seriour wrong with it.
You can try soft and hard reseting.
Instructions can be found in this pdf file http://www.palm.com/us/support/handbooks/tungstene2/en/maintain.pdf
If you cant open pdf files you need to find yourself pdf reader, google pdf reader and get one.
If soft or hardreset have any effect and the device still doesnt work even on charger then it has a hardware issue and I recommend contacting palm or the place where you bought the pda and findout about repairs and possible price, may be high.
good luck and if theres anything else let me know.
Feb 19, 2008 | Palm Tungsten E2 Handheld
Dead Palm
Need to change the battery.
Jun 01, 2007 | Palm Tungsten T5 - Multilingual Handheld
My Outlook Calendar is not synching with the Datebook on my Tungsten C, why?
Go into your desktop software and make sure your outlook is programmed to transfer back and forth.
Sep 07, 2005 | Mapopolis GPS for Palm Tungsten T, C &...
Palm Tungsten E2 Handheld Logo
74 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
