Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Won't power on.
Hose pulled out of canister because a piece broke off of the hose retaining ring. Now it won't power on even when hose is resinstalled. The is no pwwer at the three pin plug connector where the hose connects.
Thak you in advance for any input,
Randy
  • 3 more comments
  • w70442 Jan 17, 2008
    Sorry. It is 11625614503. I suspected that the hose coming out while it was on had something to do with it not running now so I took it apart to have a look and I've discovered that the 15 amp inline fuse has blown. My question now is, is the fuse a slow blow fuse or someother unique type of fuse?
    I've looked up the part that broke and it is only $17. No big deal there.
    Thanks again,
    Randy
    That's why I was asking if it was a unique type of fuse. Sears wants $5 for it though it probably comes as an assembly mounted in the sockets with the wires attached. I probably have a 15 A slow blow that I can solder in. Then again, even though it is basically just a fuse, $5 isn't that much for all that trouble.
    Thanks again for your help.
    Randy
  • w70442 Jan 18, 2008
    That's a good point about soldering the pig tail on and the filament becoming unsoldered. I thought about an inline fuse holder but I don't have one with wires big enough to handle 15 amps. All I'd have are small ones for things like car stereos. I'm thinking that by the time I buy the fuse and the inline fuse holder at radio shack, I may be spending as much as the $5 sears wants for the right part.
    At least now, I know what I need. It should be all down hill from here.
    Thanks for your help.
  • w70442 Feb 04, 2008
    The problem with the vacuum not powering on after the hose got pulled out turned out to simply be a blown fuse. There are electrical contacts on the end of the hose. They send power to the switch which is in the handle at the other end of the hose. Anyway, when the hose pulled out of the canister, a couple of the contacts on the hose apparently touched the same contact on the hose socket causing a short. This blew the fuse. I ordered the fuse assembly and the new hose socket but got impatient so I had already made a piece to fix the socket and found an inline fuse holder and installed it before the new parts came in. I bought them anyway. I probably won't install the new parts until it falls down the steps and happens again though. Sometime next month I'm guessing.....it really doesn't stay put on the steps as advertised. Thanks for your help.
    Randy
  • Lauren Junge
    Lauren Junge May 11, 2010
    Hi, what is the model number, should start 116.---------------
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
You still need to replace the swivel assembly on the hose, or you'll have the same problem. Removing the swivel is tricky. If you still need help let me know.
Posted on Feb 07, 2008
    President:
  • 1,673 Answers
It maybe cheaper by going to somewhere like the Radio Shack to get a fuse. Take the bad fuse with you and they should be able to fix you up with one.
Posted on Jan 17, 2008
  • Lauren Junge
    Lauren Junge Jan 17, 2008
    At Radio Shack you can get a pig tail type fuse, which is what this one is. Trying to solder pigtails on, the filament may become un-soldered. Either that or get a fuse holder and mount it in the vacuum, then a reugar fuse will work, that is if you ahve room for it.
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Hello, I have a Kenmore Progressive Canister Vacuum 116.20912006. It won't turn on. On the hose assembly, the end where the hose swivel is, there are 4 metal pins that plug into the canister. One of the...
Hi Susan,
if the pin has broken off you can do one of two things,
first, would be to find a local vacuum repair shop and take it there for them to look at. they may be able to look at the hose and fix it for you pretty cheaply. what cost, not sure.
second, would be to contact sears and order a new hose assembly complete with the ends. Make sure you specify complete and one piece so that all you have to do is plug it in and vacuum. Many times my customers have brought me just the hose and no ends because that is what sears sent.
Good luck.
Nov 05, 2010 | Kenmore Progressive 20912 Bagged Canister...
Power nozzle shuts on and off
HI There, When a Kenmore power nozzle cuts on and off, this usually indicates that your electrical hose has gone bad and has a short circuit somewhere. You can try and troubleshoot the hose to find out where the short is by trying to determine what position the hose is in when it cuts on and off, and try to isolate the short circuit by spinning the hose on both the end that plugs into the canister, as well as the end that plugs into the wand. Sometimes the short is in the wands, or even the swivel neck assembly on the power nozzle where the wands connect. I would say 9 times out of 10 though on Kenmore canisters, the problem is in the hose. Kenmore is actually manufactured by Panasonic, and the two brands use a lot of the same identical parts, including the electrical hose (most cases). If your Kenmore has a two position switch, with a setting for floors and carpets, then here's a link to the corresponding Panasonic hose that you can buy. The Panasonic hoses are a little more expensive then Kenmore, but the huge benefit is that they come 100% completely assembled, where as the Kenmore hose has to be assembled (which is extremely difficult even for me to do). Panasonic 3 Wire Electrical Suction Hose To Fit Kenmore Canisters On just a handful of Kenmore models, an additional modification has to be done with the internal switch. Kenmore must have had the hose modified so you'd have to buy the genuine Kenmore part, but luckily simply switching two wires on the switch will allow the Panasonic hose to work. Try just plugging in the hose into the vacuum first, and if it still doesn't work properly, then you can modify the switch. If you find that the short is in the wand or swivel neck, just use the comment field on this repair page and let me know, I'll be happy to follow up and walk you through either of these repairs as well. If this was helpful to you, please be so kind and rate the repair, or leave some feedback for me. This is greatly appreciated. Chris Jones GoVacuum.com
Jun 15, 2010 | Kenmore 22612 Bagged Canister Vacuum
Beater bar lost power - even after pushing reset button
Hi There,
If you've already tried resetting the power brush, and it still won't come on, this indicates that your electrical hose has most likely gone bad, and needs to be replaced.
This is actually a pretty common problem on Panasonic canisters, as well as Kenmore canisters (Panasonic makes Kenmore canisters).
In order to confirm this, what you'll need to do is purchase a simple electrical tester from Home Depot, or Lowes, and test the hose to make sure you have power making it through the hose.
To test this, remove the hose from the wand so you just have the handle of the hose in your hand with nothing attached to it. Put both ends of the electrical tester into the two female receptacles that plug into the wand, turn the machine on, and make sure that your hose is set to the carpet setting.
You definitely should have power coming to the hose at this part. If there is no power getting her, this indicates that your hose has gone bad. You may also just purchase a new hose (see link below), and if for any reason this doesn't fix your problem, you may return the hose to us within 60 days for a full 100% refund.
If the hose does have power at the end of it, repeat the process with the wand attached to the hose, but not connected to the power nozzle. If you have power getting to the hose, but not the wand, this indicates your wand has gone bad and need to be replaced. If you have power to your wand and hose, this probably indicates that the cord in the neck of the power nozzle has gone bad. Inspect the wire in the neck of the nozzle and see if you see any burning, or discoloration in on the male prongs.
I'm pretty sure that you'll just need to replace the hose, this is by far the most common problem on Panasonic canisters.
There are two different styles of hoses for Panasonic canisters. In order to find out which one is yours, remove the hose from the canister itself. Where the hose cuff plugs into the canister portion, look at the electrical prongs. There is either a 2 prong hose, or 3 prong hose. Here are links to both of the hoses. If your hose is a 3 position hose with a setting for bare floors, and carpets, then you have the 3 prong hose.
3 Prong Panasonic Canister Electrical Hose (Most Common)
2 Prong Panasonic Canister Electrical Hose
If this didn't fix your problem, please just use the comment section on this repair page and let me know what the outcome was after testing it with the electrical tester, and I'll be more then happy to try and do some more advanced diagnosing with you.
I hope this was helpful to you. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me, this is really what keeps Fixya repair experts answering free questions, rather then just the premium questions that we get paid for. This is greatly appreciated.
Chris Jones
GoVacuum.com
May 07, 2010 | Panasonic MC-CG973 Canister Vacuum
How can i put on the snap ring on an eloctolux vacuum hose on the end piece of the hose; it is a swivel end and an older vacuum cleaner plastic canister type
The snap ring is generally found on a Canadian made LUX AP series prior to 1982 and it is in fact a coil spring you must leave the wiring off the handle. Be sure the steel cap and rubber o ring are on the tip of the hose. Slide the handle onto the hose with the hose tip facing upright. then with a small flat screwdriver separate the hooked tip of the spring from its body and run your screwdriver around the spring,feeding it into the groove inside the hose handle, spiraling as you go. similar to how you would feed a key onto a key ring. Before inserting the wire cover try to swivel thew handle it should rotate smoothly. Be very gentle inserting the wire cover pin as it will crack the handle. Use gentle pressure with pliers to start it , then squeeze it into place with your plier jaws fully open.
Post back to advise how you have made out
Nov 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Progressive Kenmore hose canister connection broken 116,2341130
A regular person with patience can however it is tricky. Kenmore hoses have an arrow at the cuff where the corrugated hose meets the swivel elbow at the machine, and at the cuff where the handle meets the hose. If your parts fit in the handle, the cuff needs to be squeezed slightly out of round at the arrows to allow the handle to be popped out, usually by using a vice and applying a sharp blow by hand to the underside of the hand grip.
If your problem is in the lower sleeve area where dirt gets into the contacts at the machine end, there is a 1" clip with bayonets on either side. It must be compressed at the bayonets to allow the sleeve to slide off. The internal contact rings should be cleaned and polished with W/D sand paper #600 and then lubed with vaseline. Contact fingers should be spread to apply more pressure on the internal rings before reassembling in opposite order.
When in doubt Panasonic and Kenmore warranty centers will be familiar with these.
Aug 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Power cord will not retract
It sounds like the rewinder spring either came off the retainer or broke. If it broke it must be replaced. If it just came off, it can be put back on and rewound. It is a LONG flat piece if springsteel which is VERY sharp. Be Careful.
Dec 17, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Intermittent Power brush
I would first check where the hose attaches to the canister. There are 3 power leads; if one is bent, this might produce what you describe. You might even try wiggling this connection to see if it affects operation.
The other place you might see a problem is where the hose connects to the handle itself. There are 3 wires that attach from the hose. This is a bit tricky to remove as it's basically a force fit and take some effort to remove.
Dec 15, 2007 | Kenmore 22812 Bagged Canister Vacuum
Hoover Canister Pulled Vacuum Cleaner
go to thehooverstore and search for your machine. there are exploded diagrams for all hoover machines with parts lists and prices.
Sep 04, 2007 | Hoover Portapower C2094 Bagged Canister...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
234 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
