Question about LG 42LP1D 42 in. LCD HDTV
LG 4200A Tv powers on, but no picture/sound. You can tell that its on. The light is green, the LG logo is bright white. None of the the controls on the remote or on the TV have any effect. Menu options, volume up/down nothing works. Yet you can tell that the screen has power, because instead of black, the screen brightens slightly (kind of a graphite grey) and very slightly illuminated. Bad video card/controller or what? Hopefully not a dead screen.
  • 4,102 Answers
Hi the problem wouldnt be the screen instead your probably right with the video card if the screen was dead it would stay black but with it changing slightly you know the screen is gettin power.
When you press the controll does an led flash on the telly to tell you the controll is working just incase the telly is stuck on an av channel.
If you have got a dvd player hooked upto the telly switch this on with the telly on and see if the telly will work using the dvd player this would rule out the fault being with the ports on the telly not picking up the signal.
If this still dont change anything then it could either be a resistor gone or a couple or it could be what you thought with the video card/controller but their is no way of knowing without testing the resistance at certain points on the board but it deffinately wouldnt be a problem with the screen so it shouldnt cost to much to repair.
It mgith be a case that the telly has overheated and blown a resistor thse can be brought for pennys but locating will be the problem let me know what you want to do and wether you are considering doing the repair yourself if you are you will need schematics to follow off and also multimeter to test resistance at certain points on the board.
Posted on Jan 16, 2008
I have a 2-1/2 year old LG 60LB7100 TV. When I turn the TV on I get the Lg logo and sound but then I loose picture.
The back light driver can be incorporated in either the power supply board or the main board (model specific). Contact these guys and they will make sure you get the correct part. TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 28, 2017 | LG Televison & Video
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
Well dont keep it on!
By running it after it shutdown and it finally did its last pop that added another $XX to the parts bill.
The control boards (2) have now failed There are burned Capacitors ( pop!) and possibly even a few transistors burned out. This is not a DIY it is a Tech job as once changed these boards require additional tuning of the convergence factor.
Aug 31, 2009 | LG 47LC7DF 47 in. LCD HDTV
No picture
hi..make sure the cable or dvd RCA inputs red,yellow
and white inputs are proper.There may be some loose
connections.
check it out..
thank u..
rate me..
May 05, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
LG 42LP1D 42 in. LCD HDTV Logo
175 people viewed this question
