Question about Dometic Refrigerators
DOMETIC RC 4000 SMALL PORTABLE 3 WAY REFRIGERATOR
THE FLAME WONT STAY LIT...THERE IS A STRONG BLUE FLAME WHEN I LIGHT IT BUT AFTER A FEW MINUTES WHEN I RELEASE THE BUTTON THE FLAME GOES OUT....IT WORKS FINE ON ELECTRICITY (110) HAVENT TRIED DC....
THANKS
LOU
5 Suggested Answers
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
  • 79 Answers
SOURCE: Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Posted on Apr 11, 2010
  • 2006 Answers
SOURCE: dometic rm2453. Works
Interesting! Did you remove a shield that was there before? The only time I have had a problem like that is when we took the shield coving the pilot light area off and didn't put it back on right. You might want to check and make sure that everything is in place.
Posted on Aug 17, 2011
Model 7732 serial # B-92114 80-11 new 3308741.002 board 6/201 new 46-0452 thermocouple...
THESE USE SUCH A SMALL AMOUNT OF GAS ITS CRAZY... I REMEMBER STARTING MINE, MY FINGERS WOULD HURT SO BAD AFTER WAITING FOR IT TO GET GOOD FRESH GAS UPTO THE PILOT LIGHT TO STAY LIT.. THE ONLY THING YOU CAN DO IS BLEED THE LINE OF AIR AT THE FRIDGE. OR SIT THERE FOR ABOUT 10 MINUTES HOLDING THE START BUTTON.. YOU WILL SEE THE FLAME TURN FOM A KINDA WHITE TO THAT BRIGHT BLUE COLOR . THAT IT ! THAN IT WILL STAY LIT .. IF NOT THAN YOU WANT TO MAKE SURE THE BULB IS IN THE FLAMES PATH. I HOPE THIS WORKS FOR YA.. CUZ PARTS CAN BE KINDA HARD TO FIND, AND THERE NOT FUN TO WORK ON .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 24, 2011 | Refrigerators
I have a few issues with an old probably dinosaur Coleman Presidential III 7995a-856 Heating unit. I've had 3 different repairmen look at it and they're clueless. The main pilot will light and stay lit...
if the pilot is clean and and strong then this should play on to the thermocouple , i take it you have changed the thermocouple , and the connection is good at the gas valve , then if this going out could be 1, powerunit on gas valve not holding at thermocouple connection
2. Hole in heatexchanger blowing out pilot when blower comes on
I take it the pilot stays on untill fan comes on and keeps going out , I would think about not putting any more money in to this and get new if sounds as the heater has had its day ,
Dec 17, 2010 | Coleman Heating & Cooling
Pilot light on gas fireplace will not remain lit
check that you have thermopile connections are right at valve and that the flame is hitting both thermopile and thermocouple good. pilot falme may be blue but is it strong? a strong pilot has flame completely hitting both safety's. if pilot is small check pilot orifice inside pilot hood, a quick fix which may work is put vacuum over pilot hood and **** out any dust in there, just be gentle...
Feb 06, 2010 | Ovens
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
M2800 fridge
If it doesn't click or the light doesn't flicker it is probably either you don't have good strong 12 volt power getting to the fridge(12 volt required only to light on gas the first time) or else the little gas igniter module went out looks like this only sometimes black.
Now if it won't stay lit. It is something wrong with either your flame or your thermocouple. First try just blowing out the the flu right where the flame comes out blow compressed air in so if there is dirt or cobweb in there it comes out the back side. If that doesn't help disconnect your thermocouple and wipe the end and then connect it back up and tighten it. If it still wont stay lit still replace the thermocouple.
Sep 15, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
96 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
