Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Printout is 60% light grey with mostly unreadable text.
My printouts have been increasingly more illegible over the last 30 faxes. A grayed out band approximately one inch wide has grown to nearly the entire page.
    Genius:
  • 1,003 Answers
YOU NEED TO REPLACE DRUM CARTRIDGE
Posted on Jan 17, 2008
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
All printout of correspondence is in small print. How do I increase the printout size?
Font type and size are usually set in the document processing application.
If it's a word .doc,you set the size in Word.
Anything you can paste to Wordpad,highlight the text and set the font size in the toolbar.
Aug 06, 2010 | HP Office Equipment & Supplies
Fax printout (successful or not) required
Press
function
74
set
12
set
press 2 for always or 3 for incomplete only
press set
press stop
Jun 05, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Ricoh fax 2050L displays: "Check paper size", and also shifts image or text toward bottom margin by 3 inches or so. Sometimes locks up during printout.
Thru user tools check what size is said to be in the fax and if it has the optional tray that size too. -Carl
Apr 14, 2009 | Ricoh 2050L Laser Fax
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Increase the number of rings
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Lexmark X6170
Received fax is unreadable or blurry
Please go through the checklist below to see if the suggested action(s) can resolve the issue.
* Make sure the copy function is working well.
* Print a Clean nozzle page from the Maintenance menu. If the printout has unexpected white or color horizontal streaks or missing portions, print the Clean nozzle page again. If you are still experiencing streaks or mission portions, you may need to replace your cartridge(s).
* The cartridges may need to be aligned.
* You may need to ask the sender to increase their fax quality.
Sent fax is unreadable or blurry.
1. If the receiving party indicates that the fax output is unreadable or blurry, you may want to try increasing the fax quality.
2. Check the scanner glass for excess amounts of smudges and/or fingerprints. If the scanner glass needs cleaning, moisten a clean, lint-free cloth and gently wipe the scanner glass. Make sure the scanner glass is dry before scanning the next document.
Feb 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
Fax history
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Jan 09, 2008 | HP 920 Plain Paper Fax
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
73 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
