Question about Altec Lansing Multimedia Computer Speakers
No sound i just got new speakers because i thought my old ones were not working. but im still having the same problem??
  • 70 Answers
I think your speaker is working in good condition
but your computer audio out not working
due to driver or hardware problem
  1. check sound driver is properly installed
  2. using other multimedia software instead of now using
  3. check audio hardware trouble
Posted on Jan 17, 2008
6ya staff
SOURCE:
My old speakers dont work with my new pc
there could be 3 problems A) the speakers are broken B) if its a new pc it probably has a sound card with 5.1 or 7.1 surround sound capabilities so you might have plugged it into the wrong port C) since it is now this probably isn't correct but your port could be broken
To see if its problem A simply get a new set of speakers and plug them in see if it works If its B then make sure its pluged in to the green input and it says "out" not side center or back if its C return the comp and get a new one
And btw make sure you check the port with the old one and the new one to make sure that even thought you plugged it into the right port it didn't work because it was broken
Apr 06, 2011 | Computers & Internet
I have an ongoing buzzing/interference sound with these speakers - THey are new - I bought them because I thought it was the old speakers that I had which cauused the problem, but it persisted with these...
Sounds like electrical interference. If you can, try moving the speaker wires. They are like antennas. They might help to find the offending device. Otherwise try moving electrical devices away from the speakers and wire. Do it one device at a time so you will know which one is causing the problem.
Sep 21, 2010 | Logitech X-530 Computer Speakers
Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
May 24, 2010 | Acer X193W LCD Monitor
My Crate blue voodo amp head
Hi...
1st off , check the connections from the head output jack to the speaker cab. If you can get hold of a meter , check the continuity on the cable (center wire to center wire , ground wire to ground wire) both should be about 0 ohms.
Do you have another speaker cab you can try>?
You might have a speaker fuse internal on the amp too OR a secondary fuse on one of the power supply lines
Dec 21, 2008 | Audio Players & Recorders
Ne w laptop wont let me hear through speakers
hi,
you can try and plug the speaker set into an old walkman or ipod headphone jack if you have it and see if they work, if they dont work with any other input they are defective so take them back.
J
Jul 26, 2008 | Labtec Pulse 485 Computer Speakers
Kenwood Car stereo receiver
Sounds like the woofer cones are blown, no fix for that except to replace them.
You did the right thing disconnecting one at a time. Are both speakers doing that? It is a little strange that both would go out at the same time, but stranger things have happened.
If you have an extra speaker laying around someplace that you know is good (even a home stereo speaker), try disconnecting both speakers and connect the one good one to see if it sounds OK. If it sounds good or at least normal, you have some bad speakers. If the one speaker still sounds bad, you have a problem with the speaker wiring someplace. You might even need to run new wires just to rule them out as a problem.
If the problem is not the speakers, then this is a very strange problem indeed!
Good luck and I hope this helps you. If you need more help just reply back after you checked them out a little more.
Jun 18, 2008 | Car Audio & Video
Constant static
hello, all you have to do is get the ipod or portable dvd or cd player plug it and play it with minimal volume, just listen if there is clear sound coming out from the speaker, for you to know the answer to question...
Feb 28, 2008 | Logitech X-240 Computer Speakers
Computer speakers make a fuzzy sound
Hello there
Yes, Niera, you have to update, the sound drivers, and see on BIOS if something is disable on sound. other than that is posible a a speaker problem.
Jan 13, 2008 | Audio Players & Recorders
54 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
