Question about Canon imageRUNNER C3200 Copier
Cannot send email from a Canon 3380i
After we have changed to a new email server we cannot send out any documents to our internal email address. Cannot find any doc at canon or its own reference guide.
Any ideas?
  • 4theITfolks Jan 17, 2008
    Yes, I did before posting my problem.
  • Anonymous Mar 12, 2014
    can't send scan as e-mail, network is ok, smtp server is ok
    Problem Solver:
  • 14 Answers
Most likely you will have to log into the machines interface by putting the machines IP address in your web browser. Once there you will have to put the new email settings in the machine so it can email properly.
Posted on Jan 17, 2008
  • Darick Sparks
    Darick Sparks Jan 18, 2008
    If you put in your SMTP server address and the POP3 server address by nmae the system sometimes can become confused depending on your email provider. I have had to put in the actual IP address of the servers before to make them work. (ie 198.1.1.1 instead of smtp.qwest.mail)
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
I need to set my Canon Pixma MX430 to a new internet provider. How do I do this?
You need to change the router settings note the model number of the Router or modem and phone your ISP and find out the settings that need to change. The router uses an internal ip range so you do not need to change the internal ip ranges just the settings to talk with the ISP . Your ISP should be able to guide you through the router settings. The Pixma should not be affected by the change of ISP unless the internal range of IP addresses has been changed. the internal range is 10.0.0.1 to 10.0.0.254 or 192.168.0.1 to 192.168.0.254. you may need to change the email pop server and the smtp server name if stored in the printer for emailing out scanned items. The printer should have a setup CD to set these items
Aug 31, 2014 | Office Equipment & Supplies
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
How to configer email address in lotus notes
From what provider are you trying to configure email?If its gmail,
1. Create a Lotus Notes database file to store your POP emails: Lotus Notes does not create a file automatically as Thunderbird or other mail clients do but you have to manually point the mails to flow to a file that is already existing.
2. In the local Address Book, create two accounts for accepting incoming email and sending outgoing email on Gmail. Names are not important but the configuration on the two accounts is!
Account document for Incoming Gmail:
The Basics tab
a. Account name: Can be anything (I chose In Gmail)
b. Account server: pop.gmail.com
c. Login Name: Your gmail email address (complete with the @gmail.com)
d. Password: Your password
e. Protocol: POP
f. SSL: Enabled
g. Only from Location(s): Doesn't matter. Although I would recommend creating a location document specific for Gmail if you are also using Domino Server. I chose creating a location (Gmail).
Protocol Configuration tab: There is only one field here and it doesn't matter what you do with it.
Advanced Tab: This is the most important tab.
a. Port Number: 995
b. Accept SSL site certificates: Yes (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
c. Accept expired SSL certificates: Yes. (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
d. Send SSL certificates when asked (outbound connections only): No.
e. Verify account server name with remote server's certificate: Disabled
f. SSL protocol version: V3.0 with V2.0 handshake
3. Click on Save and Close to save the document and exit. Now you will need to create another account document to handle the outgoing email.
Account document for Outgoing Gmail:
The Basics Tab
a. Account Name: Can be anything. I chose Out Gmail
b. Account server name: smtp.gmail.com
e. Protocol: SMTP
f. SSL: Enabled
a. Port Number: 587 or 465 (Both are SSL port and both work)
4. Once these two documents are created, I would recommend creating a location document to ensure that you separate your gmail from your other Domino based account on the client. The steps to create are:
5. In the same local Address Book, choose New --> Location
Basics Tab:
a. Location Type: Local Area Network
b. Location Name: Can be anything (I chose Gmail)
c. Internet Mail Address: Your gmail email address
Leave the rest as it is.
Servers Tab:
a. Home/Mail server: pop.gmail.com
Ports tab: No changes (ensure TCPIP is checked)
Mail Tab (Most important):
a. Mail file location: Local
b. Mail file: My Gmail.nsf (whatever you created in step 1 above).
Update: A couple of readers pointed out that I had missed an important step in the configuration how-to. So here it is. Step C has been added to include the missed step.
c. Internet domain for Notes addresses when connecting directly to the Internet: gmail.com
d. Send Outgoing mail: directly to Internet
Leave the rest of the fields as it is.
6. There is no need to change the rest of tabs. Click on Save and Close to create the document.
Change to the the new location and you will see Gmail getting downloaded in the mail file you created.
Jul 27, 2010 | Microsoft Windows XP Professional
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
How do I scan a document to send as an attachment via email on Canon ImageRunner 1023iF
First your company must have a e-mail server.Enter the server ip address in the smtp server address in the additional funcktion,system settings,network settings page untill you get the smtp server address.
Nov 03, 2009 | Canon imageRUNNER 1023iF Black and White...
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
May 14, 2009 | Konica Minolta Office Equipment & Supplies
How do you set up email on a networked canon ir4570
If your machine has universal send feature installed you will need the following items
email server address i.e mail.bellsouth.net (for bellsouth dsl customers)
you may also have internal mail server, ck with IT dept to see if applicable
whether your email server requires authentication or not if so you will need login and password so email will pass from machine to server then routed to destination
settings are available and easily programmed thru the RUI (remote user interface) by typing the IP address in your browser and click on add'l functions scroll down to bottom of the page and look on right column under email and ifax settings. There is the area to input settings.
Once that is set browse to address book to enter scan to email addresses.
All can be done from main control panel also.
Hope this helps, also on the "send" page is where you go to perform the scans not the "scanner" tab. That is also where you can change file formats from tiff, pdf, or jpeg.
Regards
TankMurdock
Apr 23, 2009 | Canon imageRUNNER 1023iF Black and White...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
E-mailing docs
Is there only one email address that doesnt work, or are they all not working?, also have you had a change on your network lately?, your copier will be tied into your email server and any changes will directly affect your copier, if so you may need to call in your IT to input the new server name into the copier.
Dec 04, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER C3200 Copier Logo
1,294 people viewed this question
old marine
old marine
