Question about Nortel Norstar 16-Line PBX Speakerphone
Nortel CallPilot Manager
I am trying to change the message that incoming callers hear after we have put our system on Night Mode. I have forgotten my password for the CallPilot Manager website. How can I get a new password or download info on how to change our greeting and Auto Attendant info?
Thanks, Laura Adams
laura@carpetcompany3.com
407-888-8008
We have a Norton CallPilot system - can I arrange it to call forward to outside lines from each extension?
Posted on Dec 23, 2009
    Scholar:
  • 146 Answers
I think the best thing I can do is give you the link to the user guides so that you can pick the one most suited to your application, as Call Pilot has many facets ... Good Luck
http://support.nortel.com/go/main.jsp?cscat=DOCUMENTATION&poid=8165&viewOptSelect=3|1
Posted on Jan 16, 2008
Is there another way to know I have a voicemail without checking the lines periodically and listening for the beeps? Also when I transfer a call to another number it does not provide the callers ID on
These features are handled by the system, not by the phone. You need to ask you administrator to enable the message waiting indicator on your voice mail. When you transfer a call the incoming CLID flashes only for a brief second on the target display. I am not sure that can be changed - it depends on your Nortel hardware and OS version.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Oct 24, 2014 | Nortel Networks T7316E Enhanced Telephone...
When I put my t7316E on "night" it only rings half ring then sends call to answer machine, Any way to change to a few rings so I can answer it if needed
That is generally how Night mode works - alerting you to a call then directing the caller to voicmail night message. You want to change the Forward No Answer setting in that mode; if your system doesn't support that, set FNA in regular (non-Night) for the attendant phone.
Oct 09, 2014 | Nortel T7316E 2-Line Corded Phone
Change date and time on nortel t7616e
That is a system setting... Depending on what KSU common equipment you have. Feature **TIME might do it, systems with Caller ID Cavan set the clock on an incoming call.
Jan 15, 2014 | NorStar T7316E Corded Phone
How do you put answering message on phone 4150
Your system must have a voicemail system. And your phone must be call forwarded to the voicemail system.
Jan 16, 2010 | Mitel Superset 4150 Phone
How do you change the incoming message anew caller
on the system you use the vm msg button and your password, you also need to know which numbers your messages greetings, hold, holiday are set at then that is the msg you change.
vmmsg
*# number changed
password
number you are changing
Nov 10, 2009 | Samsung DCS 12 Corded Phone
I have a callpilot 100/150 we acquired an add-on
First thing, the Call Pilot is your voicemail, not your telephone system. Your telephone system is most likely a Norstar CICs unit.
If the lines(trunks) are analog, it is the local telco provider that is handing out your caller ID.
Outgoing caller ID is not one of the features of the system for analog circuits. If you were running a PRI or BRI, then the system can hand out the caller ID. I would ask your telco provider to check the outgoing caller ID once again.
Jun 10, 2009 | NorStar CallPilot 100
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Apr 16, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Retrieve a message
Depending on what VM system you have there is a feature # you key in.
For instance the Nortel Callpilot feature is "feature, 981" If this is your first time logging in you will have to enter a password. Contact your systems administrator to reset or set your password to never ask.
Aug 22, 2008 | Nortel Meridian M7208 Corded Phone
Nortel neworks voice
If your system is a Nortel Callpilot just log into your mailbox, then press 8, the first option "Record your name in the company directory" is what I think you're looking for.
Aug 05, 2008 | Nortel Meridian M7208 Corded Phone
Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Oct 25, 2007 | Lands Phones
Nortel Norstar 16-Line PBX Speakerphone Logo
2,440 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
