Hello, Correct me if I'm wrong, but I assume you don't mean it's going onto your floor right ? You should make sure your drain hose is either... A) not lying on the floor into a floor drain...B) the drain hose "stand pipe" is not too low, i.e. below the selected level of the washer water level when it's full/filling. or...C) the drain hose isn't shoved down inside the "stand pipe" too far, i.e. below the desired water level in the washer. Any of these scenario's will cause the machine to syphon or drain as quickly as it fills in other word's. This is what would cause a situation as you described "water fills and drains from the bottom..." Hope that help's and if so please take a minute to rate this soulution provided for you here at fixya. If not, let me know and we can move forward from here. Good luck. macmarkus :)
Do you mean it's leaking out the bottom or that it's siphoning out the hose as fast as it's filling? If it's siphoning out, make sure the drain hose is NOT sealed airtight to the drain pipe, or it will siphon out as fast as it fills. If it's leaking out, you need to remove a panel and look to see where it's coming from.
Front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
What this actually signifies is that there is a
problem with the spray arms; they are blocked, needs cleaning.
Then, check on the filters as well, its an
uncommon problem, but once cleaned, run the machine on a hottest wash, hope it
clears the problem. Check inside for the hose (see if in place or off the
top spray bar)to check whether water is going into the spray bars and spray
arms work well. ----------
The 5 flashes indicate a spray. Pump fault,
either blocked or motor fault.
Press and hold the start button until
the light goes out.
Select
a program and try the machine again.--------
This should help.keep updated.Thanks.Helpmech,.
