Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Knocking sound in agitator
It looks like it's the agitator.. there's a loud knocking sound in the washing cycle... the washing machine is well balance, everything looks ok... except of the sound.
I read on a website that i should clean inside the agitator but i'm not sure how to. the screw in the agitator makes it spin if I unscrew it...
how do you remove the agitator and is it a possible solution?
  • Tipoudeli Jan 16, 2008
    update: I forgot to say... the sound is louder when it is washing fast... and we don't hear it in the spin cycle.
  • 770 Answers
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Posted on Jan 26, 2008
Washing machine knocking on spin cycle
Unbalanced washing causes that. If it worries you, open the door and redistribute the wet washing.
Oct 21, 2017 | Washing Machines
Washing machine knocks and dims lights only during rinse cycle
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
Jan 24, 2013 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Sep 15, 2009 | GE WJSR2070B Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Dec 27, 2008 | GE WJSR2070B Top Load Washer
Model MAV3855AWW revision 26 loud knocking sound during agitation, weak spin clothes are soaked after spin cycle belt replaced
The problem is 2 fold. The "knocking" noise is indicative of brake rub. The fix is to replace the rotor & stator. The reason that your clothing are coming out wet is because the brake is dragging along a polished stator when in spin and cannot get up to its proper speed as a result. The 2nd item that should be replaced is the thrust bearing assy. This is what enables the transmission to transition from agitation to spin... Hope this helps... Bill
Apr 30, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
459 people viewed this question
Dan Webster
Dan Webster
Sal De
