Question about KitchenAid KFP750 Food Processor
The spindle (middle thingie) is broken
The spindle in the middle of the machine (the part that always stays there even when the bowl is off) is broken. The little "lip" that the bowl hooks onto to lock it has broken off. I'd like to replace it at home (it's no longer under warranty, of course!)...is that even possible??? Is there a schematic somewhere??
Thanks so much!!!
I don't know about the little lip you're referring to, but the central spindle that comes up from the base of our KitchenAid 12 cups food processor KFP750WH0 splintered and broke while we were using it. We ordered a replacement motor sleeve shaft part number KA8211849 from the Gourmet Depot for $4.95 plus $3.50 s/h. Removing the broken plastic sleeve shaft was the difficulty; it isn't glued or screwed on but somehow it didn't want to be pulled, pried, or cut off. With the help of our neighbor fix-it man and all four of us working at it with screwdrivers, we got the old broken part up and off. Pushing the new one onto the metal motor shaft was easy, and it was fixed!
Posted on Jan 05, 2009
  • hitch2 Oct 03, 2010
    Thanks so much! I had the exact same experience and searched high and low for replacement part information (including a fruitless call to Kitchenaid) until I found your post. I ordered the part from Gourmet Depot was able to pry off the plastic sleeve with a a screwdriver, time and lots of patience. The new sleeve fits like a glove and I am back in business.
  • Jim Smith Dec 17, 2011
    Ditto! Had the same issue...what a task getting the old one off. I finally just cut it down the side and took it off. Whew!
    Amazon has the KitchenAid part# 8211849 Motor Shaft Sleeve
    Price: $2.99
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
I used the shredding blade and now can't get the inside spindle to pop off or the bowl. It will still work if I put the blade in and turn it on. How can I get the spindle and bowl loose?
I posted about this somewhere else. Sounds simple but it worked for me. Give the spindle a good whack with a wooden spoon all the way around and it will come loose.
Sep 01, 2009 | KitchenAid KFP750 Food Processor
My mini cuisinart stopped working
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals (p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Instructions for the food processor of my Cuisinart Duet
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
Cannot get food bowl off the Oskar food processor
My Oskar has two locking teeth on the bottom of the bowl. One at the 3 o'clock position and one at the 9 o'clock position. Grabbing the bowl at the bottom with one hand (using thumb and one finger), I twist clockwise (to the right) about 1/4 inch and the bowl unlocks and lifts off directly. (my unit's spindle doesn't have anything to do with locking the bowl. My unit must be 15 to 20 years old btw)
Jan 13, 2009 | Sunbeam 4817 Oskar Food Processor
Bowl handle doesn't make connection
I had this problem, I finally stuffed a tiny piece of tin foil into the hole the spring is supposed to go into to activate the machine. It works, but it is always on, even if the bowl is not locked into place so I have to be careful. I just store it unplugged.
Nov 16, 2008 | KitchenAid KFP750 Food Processor
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Wolf Gang Puck 620 Food Processor - Broken Blade - Need replacement
You guys with the Wolfgang Puck processor, need to go to this website, they have what you need but not what I need, I need the spindel, the blade is $9.99 www.wpcookware.com
Jan 22, 2008 | Wolfgang Puck BFPR0015 Food Processor
KitchenAid KFP750 Food Processor Logo
812 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Don Eagan
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
