Question about InFocus ASK Proxima M2+ Multimedia Projector
Ask proxima m2+
Put a new lamp in- projector fans dont run and green light comes on for an instant then back to orange
Lamp gets brighter & brighte within a minute & immidiately color wheel stops rotating & projector goes to standby mode. for 3 to 4 minutes again same symptom contimuously observed pls guide me which part is suspected
Posted on Feb 16, 2008
I have a epson tw1000 projector i bought and i ordered two new lamps off of amazon got the lamps put one in the projector flipped the power switch on on the back of the projector light turns orange to let...
Lamp ballast is not work , you can replace a new ballast or to repair it.
Have a good day!
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 23, 2013 | Office Equipment & Supplies
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Hello., I've just tried to power up a Proxima 9310., and for the first time in my experience the orange light has come on and shut down has effected after a couple of seconds. I would like to ask for...
hi,
Time to replace the lamp of you projector.Lighting up of the orange light indicates that. All the projectors comes with self disorganizing program. if there is any complaint except power supply that will indicated by the projector by its self disorganizing system.
switch OFF the projector for some time. then power it ON. if picture come then first of all reset the lamp hour timer. To do the same do the follwing
1. Press the menu button and press rear click button or select button
2. Select settings press the rear click or select button
3. On setting display select Lamp age and press the rear click or select button
4. Move the arrow to Yes and press the rear click select button
OK will displayed and wait for your conformation
5. Move the arrow to Yes and press the rear click or select button
if there is no picture when you switch on the projector then go for a new lamp. you hve to do the reset procedure after replacing the lamp. It is always recommended the you should reset the lamp hour only after replacing the lamp.
ok
Apr 04, 2011 | InFocus Proxima Pro AV 9310 Multimedia...
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
I have a proxima s540 ultra lite data
From what you describe, it sounds like a fan isn't working. When you turn on a projector, it will go through a quick self test--checking that everything is operating correctly. Some of the fans send out a signal to the main board telling it that they are running. If no signal is received, the board senses this and auto-shut down occurs to protect the unit from heat damage. The errant fan could be spinning but the computer pulse might not be being generated. It will require a tech to find this out.
Aug 31, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
Lp790 projector does not turn on
it would still try to turn on even iff there wasn't a lamp in it. if it won't even turn on, see if the switch inside the lamp door is working. it won't turn on if the door is open. also, the thermoswitch on to of the lamp compartment (through the inside) may also be blown and needs replacement.
May 12, 2009 | ASK Proxima InFocus LP790 and Proxima...
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
InFocus ASK Proxima M2+ Multimedia Projector Logo
370 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
