Question about Panasonic DMR-ES10 DVD Recorder
Stuck in 'set 1'
Whenever i touch a button, any button, on my remote, the display on the dvd player shows 'set 1' for a few seconds, then goes back to 'play'. i can use the buttons on the dvd player, but since it only has a play and stop button, use is very limited. ideas, anybody?
  • montyandluke Jan 23, 2008
    thanks, mbyther, you're my hero!
  • Anonymous Dec 14, 2008
    aluomala, thank you! that fixed my SET 1 problem on the BD30 player!
    New Friend:
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Posted on Jan 22, 2008
I had a similar problem (it showed "Set 2" in the display instead of "Set 1", but highly annoying nonetheless). I tried the solution as presented (holding the "1" button and "Enter" for 10 seconds), but it didn't work. Rather than giving up, I put on my thinking cap, I tried (wait for it.....) holding the "2" button while holding down the "Enter" button. It worked. So, I suppose, it comes down to whichever "set" number is being displayed being used in conjunction with the "Enter" button to reset the remote.
Thanks for the help, and I hope my alternate solution helps out someone in need,
Allan
Posted on Nov 11, 2008
When i push the buttons on the remote it keeps saying set 1
The remote is probably set to another command mode (for example, SET2, DVD2 or RC2 depending on the model unit) or the batteries were replaced recently, so the remote needs to be reset. You can try this: take the batteries out of the remote (as if to replace them), press any button to clear the remote's buffer, then re-insert them. Point the remote at the player, then press and hold 1 and ENTER/OK buttons together for approximately 10 seconds, then release. This should restore the remote's function back to your player. This 'remote reset' must be done whenever the batteries are replaced, otherwise either the remote will not function correctly, or the device will not recognise it.
Very simple, takes a few seconds or so, and costs nothing to try.
Apr 17, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Will not play DVD from other regions. Specifically, plays a few but mostly does not play DVD from Australian region. I resdie in Serbia. thansk for any advice or work arounds on this issue. We inherited...
Your dvd is locked to a region code so will only play dvd's for region it was made for.
good news is that you can unlock most dvd players to be region free.
URC-3445 ONEFORALL
First of all set the command mode of the recorder to "DVD1"
from the menu and from the remote.
After that
1. Press DVD on the remote control
2. Hold MAGIC button (or SET Button) until the led flashes twice.
3. Press 0, 5, 3 and 3 and the led flashes twice.
4. After that the URC can manage the recorder...check it
If not, then use the code search (have a look in the manual of the remote control).
When the rc works, then step over to
MAIN PROCEDURE (DON'T HAVE ANY DVD INSIDE THE PLAYER)
1. Hold MAGIC button until the LED blinks twice
2. Now type "994" (then LED blinks again)
3. Press the MAGIC button (shortly)
4. Now type 001891
5. LED blinks twice
6. Repeat steps 1-5 and enter instead of step 4 the codes 002552,000953,002214,000795
7. Put the player on standby (and be sure that there is no DVD inside)
8. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes on
9. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes off
10. Then it is done. Your DVD-Player/Recorder is Codefree
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sony SLV-D990P DVD Player/VCR
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
Dvd/vcr combo Panasonic dmr-es35vs
I also encountered a similar problem and did some research on the internet. The way to fix this problem is hold the 'Enter' key and while holding the enter key, press number 1 for a few seconds until the display changes to C1 or SET 1 error goes away.
This should fix the problem. Atleast it worked for me. All the best!!
Sep 24, 2008 | Panasonic DMR-ES35VS
Remote is Stuck in DVD 1 mode
I had this same problem (DVD1). Resolved as follows: With DVD player on, pointed remote at DVD player, pressed and held the 1 key and then pressed and held the enter key (both at same time) until I saw the DVD1 on the DVD player display disappear. Now everything works.
Jun 23, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Daewoo DV6T811N DVD Locked
Your Child Lock has been turned on.
Press the power button of the remote for about 8
seconds. No buttons of front panel and remote can be
operated now and Lock indicator (“LOCK”) will be
displayed on window display.
To release child lock,
press the power button of the remote control for
about 8 seconds.
Good Luck.
Apr 08, 2008 | Televison & Video
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Panasonic DMR-ES10 DVD Recorder Logo
236 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
