Question about Casio FX1.0 Plus Calculator
My Casio isn't working!
Hi I have a problem with my Casio FX 1.0. It only shows a square black box and an arrow in the rigth down-corner. I can move the black-box, but I can't press anything! Well.. I can press it, but nothing happens :)
Hope there is a simple way to fix this... Hope its just me that doesn't know my friend the Casio well enough.
  • Anonymous Mar 26, 2008
    how to calclulate 15^7mod77?
  • Anonymous Nov 26, 2008
    that isnt the solution please read carefull and them answer i have the same problem..
  • 682 Answers
Clean the keypad and the printed ciircuit carefully with clean piece of cotton cloth.and apply
fresh battery after cleaning.
Posted on Feb 29, 2008
I get lots of little squares you can see the result but behind theres alot of little squares
The calculator belongs to a new generation of scientific calculators that enjoy the feature called MathPrint by TI, Natural Display by Casio, and WriteView by Sharp
When the calculator is configured to work with this Display you are shown a template as you would see on a textbook. The squares are the places where you enter the numbers. For example when you press the fraction key the calculator displays a the picture of a stacked fraction with one square on either side of the horizontal fraction bar. The square where the cursor is located and blinking appear dark. You start entering the numerator there, then you use the down arrow to move to the denominator. When fraction is finished you move the square away from the fraction to the main line using the right arrow key.
I hole this solves the annoying problem of the mysterious squares.
Please read the manual to learn about this feature so that you can decide whether to take advantage of it or not.
Feb 19, 2013 | Casio fx-300ES Calculator
Casio classpad 330 isn't square rooting
Select Main Menu. At the top left of the screen tap the down pointing arrow, select Settings, then SetUp, then Basic Format.
Check the Decimal calculation box.
Nov 05, 2012 | Casio ClassPad 300 Calculator
Square root button on FX-570ES plus. trying to find out how, when using the square root button - to stop it from square rooting the entire equation... eg if i want to work out
Press right-arrow when you're done with the argument of the square root. For example, from page E-15 of the manual, to calculate 1 + square_root(2) + 3, press 1 + square_root 2 right-arrow + 3 =
Jul 21, 2012 | Casio FX570ES Scientific Calculator
How do i enter a fraction on the calculator
In math IO mode, press the key marked with a two-level fraction symbol (1 solid square in numerator, fraction bar, 1 empty square as denominator.) A fraction template is displayed. Use the up or down key to move cursor to numerator or denominator. Press [=] key when finished.
Oct 20, 2010 | Casio fx-300ES Calculator
How to solve log base 2....
  1. In MthIO, pressing the log key displays a template: the log function and two squares, one smaller and below the main line, and another, bigger square/rectangle on the main line.
  2. Use the down arrow to move cursor to the smaller square end enter 2 as base.
  3. Use the up arrow to move cursor to the bigger square and enter the number whose binary log you want to calculate.
  4. Close the right parenthesis.
  5. Press the [=] sign at the bottom right of the calculator.
MthIO is the default Input/Output format of the calculator. To set it
  • Press [SHIFT][MODE] to access (Setup)
  • Select [1:MthIO]
Aug 17, 2010 | Casio FX-115ES Scientific Calculator
Integral of sinx how to calculte in casio fx991 es
Configure the calculator to be in MathIO : [SHIFT][MODE][1:MathIO].
Press the Integral key, the one judt beloe the [ALPHA] key.
The template of the integral appears, with the cursor in larger rectangle. Enter the function the screen displays the integral, a small upper sqaure, and a small lower square. The left parenthesis of the function is already supplied by the calculator.
Press [ALPHA] X to enter the argument of the function.
Press the right parenthesis.
Remain the limits.
Use left arrow to move the cursor just before the s of sin and press down arrow to enter a numerical value for the lower limit.
Press the up arrow to move cursor in upper square.
Key in the numerical value of the upper limit.
Press [=].
Warning. To have meaningful result, make sure the angle unit used is conform to the problem you are trying to solve.
Hope it helps.
Nov 01, 2009 | Casio FX-300MS Calculator
Scientific notation
I found a way to show you how to enter it on your calculator. Make sure you are in Math Input Output (MathIO). To effect that press [SHIFT][MODE][1:MathIO]. Calculator clears its screen
Press [SHIFT] then [Fraction template key] the one just below [calc]. I will show an image of the template in a picture below. Then you enter 4.6x85000 in the upper square of the template. Press the [Down Arrow] to move cursor to the lower square and key in 3570x0.0843. Then use [Arrow right] to move cursor to the level of the fraction line and press [=]. Hope it helps.
Oct 06, 2009 | Casio FX-115ES Scientific Calculator
How do you do a linear regression graph on a casio graphing calculator?
I am aware that the solution provided below is valid for the CFX/FX-9850G/GB/ but I will supply it. I remain convinced it will help you for your calculator.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
Hope it helps.
Oct 04, 2009 | Casio FX-9860G Graphic Calculator
Standard Deviation
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
x bar =74.7142857
n = 7
minX =56
Q1=68
Med =75
Q3=85
maxX=90
Mod=90
Hope it helps.
Mar 09, 2009 | Casio CFX-9850G Plus Calculator
Casio FX1.0 Plus Calculator Logo
121 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
