Question about Fujitsu Siemens AMILO Pro V2000 Notebook
External monitor connection
I have purchased a lead recently to connect my amilo pro v2030 to a tv screen. i connected the cable between the tv and laptop and pressed fn + f3 to change to external monitor output but can t get it to work , i have also tried altering some settings in display properties as advised before but this didnt help, can someone please help me achieve my goal of getting my image on the tv screen thanks eamonn
  • eamonn1 Jan 17, 2008
    tried this but seems to do nothing
  • Anonymous Mar 27, 2014
    I have gone into applications manager to restart and this does not solve the problem.
Try the keys at boot up.
Posted on Jan 16, 2008
6ya staff
SOURCE:
I have taken of my v2030 screen there is a 2 wire plug white and pink from the screen and I cant seem to find where it have to go
Possibly you pulled it out when you took off the screen.There should be a small socket or connection where it came from on the board of the PC.You would need to do a search for a new screen and how to install it.Try the link.Possibly it can help.
15 0
Aug 22, 2015 | Fujitsu Siemens Amilo Pro V2030 Laptop...
The display on my Amilo Pro V2030 is black after it fell on the floor. Does this necessarily mean that the display is dead and needs to be replaced or external monitor used? Could the problem be fixed in...
May be a loose connection, at best, at worst, HDD damaged, etc., etc., etc.. Does it boot? Fan spins? LED's Blink? Sound? Anything? If you connect a External Monitor does it work? There are cable at the bottom and rear of the monitor that can come loose.
May 04, 2013 | Fujitsu Siemens Amilo Pro V2030 Laptop...
Amilo pro v2030 laptop
oh boy,, !!! ur screen is damaged and better replace it !! no choice left !!! Hard luck ...
May 04, 2013 | Computers & Internet
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Fujits amilo pro v2030 will not boot up
Are you getting the BIOS info on the screen?
If you can access the BIOS check all the setting.
Hard Drive installed, Boot Sequence and so-on.
If you get NOTHING on the screen but can hear it "running", try plugging in a Monitor, you may have to find the monitor key, usually = hold "Fn" + Press "F5" to switch screen to monitor to both.
Oct 08, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
No vga driver for amilo pro v2030
You can find the driver link here. Amilo Pro v2030 VGA Driver scroll down and you will find the link "VIA/S3G UniChrome Pro IGP". you must register first to download the driver. Just use free Membership in signing in and just skip or select no thanks in other membership offer..
Hope I Can Help
CLCTECH
Apr 28, 2009 | Computers & Internet
How to use two screens concurrently.
Plz you can see the right side of your laptop then sow a port,this port is external monitor.connect Monitor cable,then you can use it.
Apr 03, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo Pro V2030 - Wont Boot
Try connecting it to an external monitor as the display may have gone out on you.
Feb 12, 2009 | Fujitsu Siemens Computers & Internet
External monitor for amilo pro v2030
hi
when the external monitor is connected hold down the function key " f n " ( which is located 2nd on left of lowest row ) and then press either the F4 or F5 function keys on top line....the one that has a small icon like a rectangle or tv screen on it ....it has usually 3 toggle positions so if it dosent work first time then just press the same key again (still holding fn key) until it allows the monitor to get the signal.....if F4 dosent work then go thru the same sequence with F5 but depending on the laptop model it could be any one ...F3/F4/F5/F6 the usual suspects....
hope this helps
Jan 04, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
494 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Cliff itsasecret
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
